Avation Fuel
Old Aug 10, 2002 | 03:23 PM
kkk93rex's Avatar
Avation Fuel
Are there any reasons why I cant run Avation Fuel its so much cheeper. Any disadavatges advantages please let me know thank you.
Old Aug 10, 2002 | 03:33 PM
maxpesce's Avatar
Ex fd *****
most AVGAS is leaded and will destroy your cats and foul your plugs
Leaded and Unleded AvGas has additives to reduce Volitility and usually lacks the detergents that automotive gas has. also AvGas just looks cheap because the excise tax and sales tax are usually NOT included in the quoted "PUMP PRICE" JET fuel is Cheap because it is not GASOLINE at all but rather KEROSENE based.
Old Aug 10, 2002 | 04:14 PM
kkk93rex's Avatar
If i have no cat how oftan are we talking about replacing the plugs? I doesnt matter how I cut it 108 AVGAS is way cheeper than 108 race fuel. I could live with replacing them once a month for the price diffance.
Old Aug 10, 2002 | 09:16 PM
cdk 4219's Avatar
Av gas is not designed for automobiles and will not properly fuel your car. Above and beyond the possible lead which will destroy your O2 sensors it will not run as good as race fuel. If your engine is stock or even slightly modified, then even race fuel will actually slow the car down it burns slower than lower octane fuel thus eliminating detonation but if the engine isnt doing that then slower burning fuel wont help anything but drain your wallet. Dont do the av gas I have tried on higher compression engines and it sucks
Old Aug 10, 2002 | 09:17 PM
RE AV GAS
is cheaper as ststed prior.. no tax... also caution is required as i believe it is produced with a slower burn rate= slow flame front.. Carter
Old Aug 10, 2002 | 11:05 PM
word CDK
Old Aug 11, 2002 | 07:58 AM
Flybye's Avatar
It's never fast enough...
A few years back I put AVGAS in my FD. It ran smoother, and the exhaust smelled like candy I stopped doing it because there was this big debate about it and its lead content, and back then I had only intake and CB. Now I have no cats and the PFC, and I am VERY curious to see how AVGAS will affect the knock readings, but the station that had it before no longer offers it . I gotta find a station that carries it again...
Old Aug 11, 2002 | 08:58 AM
bajaman's Avatar
Constant threat
As several here have already stated, aviation fuel is NOT for use in cars, just like automotive fuel will NOT work in aviation engines. Browse some of the pilot forums, especially the small plane/ultralight forums.
One of the deals with av gas is all the additives that are formulated in for the fuel to burn at high altitudes.
Now, in the "old" (yeah, "MY" days!) of leaded fuels and high compression motors, you COULD gain some benefits by running a 10:1 auto-to-avgas ratio of fuel.
But the really technical guys of the time noticed that re-jetting of the carb was often required for maximum performance.
If anyone was to try avgas in a car engine today, I would not use anything but 100LL (low lead) and even then use it blended at a high ratio.
Gas is not gas is not gas here folks.....look at the toxic brews that F1 cars used to use. That stuff resembled pump gas about like Rosie O-Donnel resembles Britney Spears.....sure, they are both women but that is about it!
Old Aug 11, 2002 | 12:32 PM
cruser's Avatar
I run 100% avgas 100% of the time, no problems as of yet. Was recommended to run this by my tuner who runs it in all of his high hp cars. I do have the O2 sensor turned off from the Power FC since I know the fuel will clog it up anyway. My car actually idled much better with the O2 sensor turned off.
Old Aug 11, 2002 | 01:09 PM
bajaman's Avatar
Constant threat
What type and what octane? You seem to be the exception rather than the rule, but depending on mods you may have found the perfect fuel for you.
The other problems is getting around the tax issue. All the guys I used to know that bought avgas had to do it on the QT, as no one would pump it into a car as it is very illegal. It must suck having to transport fuel......
Old Aug 11, 2002 | 02:07 PM
cruser's Avatar
I bought a drum and store it in that. Actually the airport I get mine at said I could just drive up to the pump if I wanted to???? I don't know off the top of my head which type and octane it is, I will find out for you. I just go to the airport pump and get it. They only have one type at the airport I go to.
I am running ported engine, T04s, no cats, and everything else to go single, injectors, fuel pump, etc. I am sure it saved my engine on the dyno. One pull went to 12.5 a/f, yikes. Made good power at that a/f though .
Old Aug 11, 2002 | 02:35 PM
maxpesce's Avatar
Ex fd *****
The caviat about pumping it into you car at the airport is that they (The FBO) are then required BY FEDERAL LAW to charge you Federal excise taxes and BY (in most states) STATE LAW, state excise and road use taxes - in CA this runs to about $.559/gal
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
