vented hood help with heatsoak?
Old Aug 10, 2002 | 03:12 PM
trigeek37's Avatar
when my car sits after driving it, espically slow for a while, it get hot - like 100+ C. when I start up my car it revs up & down between 2000 & 3000 rpm. after starting the car the temp starts to drop right away, reaching a manageable 90 C after just a few min.
so, the question is:
would a vented hood help eliminate heat soak after the car is shut down?
Old Aug 10, 2002 | 03:40 PM
the_glass_man's Avatar
Will u do me a kindness?
Originally posted by untaymd
actually the vented hood will allow the release of blue pigeons..
Um, Okay. But yes a vented hood should help with heat soak. Which hood works the best??? Hmm, thats a good question. The Scoot is wild the Mazdaspeed is not.
I like the Border hood myself.
There are tons of others as well.
Old Aug 10, 2002 | 04:29 PM
oneflytrini's Avatar
Stabbed by a pen
the RE AMEMINYA is nice....
which ever hood as long as its made by him
Old Aug 10, 2002 | 04:33 PM
94touring's Avatar
My vented hood has reduced my underhood temps dramatically, especially when at an idle. Whenever I cut the car off I can feel the heat pouring out of the vents.
Old Aug 10, 2002 | 04:57 PM
trigeek37's Avatar
94 touring - have you eer gauged how fast your car cools down after you shut off the engine?
Old Aug 10, 2002 | 06:38 PM
94touring's Avatar
Well not really, I don't have any numbers showing before or after. On a hot day after I park the car, if I were to lift the hood, it is surprisingly cooler than before the vented hood.
Old Aug 10, 2002 | 06:44 PM
Just run without any hood, its cheaper and works better.
Old Aug 10, 2002 | 07:42 PM
trigeek37's Avatar
but then everyone would think I was driving a honda, and none of us want that....
Old Aug 10, 2002 | 07:51 PM
GoRacer's Avatar
Speed Mach Go Go Go
Yes, if you are using a SMIC. There is no place for the heat to escape without a vented hood and that is the drawback of the SMIC.
Old Aug 10, 2002 | 10:12 PM
rx7dv8's Avatar
Vented is the way to go.
Old Aug 10, 2002 | 10:39 PM
DELTA_Rotary's Avatar
Bourbon King
I like the fastpac vented hood myself. Its not very wild and crazy and keeps the lines of the car intact.
Old Aug 10, 2002 | 11:37 PM
94touring's Avatar
I know i've posted this several times, but since DELTA_rotary likes the fastpac, here is my car with that hood.
Old Aug 11, 2002 | 12:07 AM
Originally posted by Dont_Be_A_Rikki
nice hood but a little to boxy for my tast. I stick to mazdaspeed.
-Rikki
I agree, I like the way it vents look and they are big. But it looks a lil boxy or home made while the mazdaspeed one flows better with the lines of the hood and the car.
Old Aug 11, 2002 | 12:10 AM
jspecracer7's Avatar
1JZ powered
I'm not sure about heat soak because I have FMIC, but I did notice that my water temps dropped 2 degrees celsius from 81 to 79....that's so low that the thermostat wasn't even opening up!...
...I read somewhere on the forum that the scoot FD was dyno'd with water temps at 80 and 90 degrees respectively. With the 90 degree temps, they actually saw HP increase over the 80 degree temps....
...so Now I run at 92 celsius
Old Aug 11, 2002 | 03:14 AM
trigeek37's Avatar
my normal operating temps very rarely fluxuate from 88 to 92 C, so I think I am fine there. I just want to avoid the increased heat I get when I stop & park for a bit.
On a sorta related note: I am now going to do the fan switch mod - will that run down my battery a lot if I run my fans for say 10 to 15 min after the motor is shut off? I am using a smaller sized Miata battery if that makes any impact....
Old Aug 11, 2002 | 07:33 AM
Fd3BOOST's Avatar
Recovering Milkaholic
My engine seemed to cool alot faster after I put the MAZDASPEED hood on. My IC pipes never get hot now, Not even the turbo side.
It's to late for me though. My coolant seals went out anyway. Bodyshop .start and stop start and stop crap killed my engine after 2 months of it.
ls1swap
Jun 3, 2024 03:25 PM
LongDuck
Oct 7, 2015 08:12 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
