Unburned fuel
Old Aug 9, 2002 | 01:59 AM
faisalk's Avatar
Unburned fuel
My car emits a lot of unburned fuel. Is this normal for all rx-7's or my car seems to have a problem? Also I only have a cat Back and intake installed in my car but the boost on my boost gauge is 0.9kg/cm3=13 psi. Are my turbos generating a lot of boost with only 2 modifications or is this also normal?
Old Aug 9, 2002 | 02:05 AM
Kahren's Avatar
i am not a girl
if you dont have any sort of fuel managment on your car and u are hitting 13psi u better turn the boost down to stock level which is 10 or you will blow your motor
Old Aug 9, 2002 | 04:59 PM
Ouijan's Avatar
Rotaries in general spit out more unburned fuel than pistons. Make sure that this unburned fuel is coming out your tailpipe and not from a leaky FPD.
And kahren is right - if you are hitting 13psi with a stock ecu, you are pushing detonation limits. I would suggest some sort of boost controller (manual [Home Depot] or electronic [i.e. HKS]).
M
Old Aug 9, 2002 | 05:05 PM
Manolis_D's Avatar
Ouijan: All a boost controller can do is raise the boost! I'm not too familiar with the TT wastegate controls, but i'm pretty sure it will take more than that!
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
