Sway bars. SA to FB
Old Aug 7, 2002 | 01:12 PM
MarkPerez's Avatar
Tennis, anyone
Sway bars. SA to FB
Are the -SA sway bars larger dia. then the stock FB's .?
and will the -SA sway bars fit an FB ??.....peejay ??anybody ??
Old Aug 7, 2002 | 01:33 PM
jeremy's Avatar
male stripper
rear should but the front suspension i know is slightly different. not sure if this affected the swaybar or not.
Old Aug 7, 2002 | 05:27 PM
MarkPerez's Avatar
Tennis, anyone
Almost there,,peejay knows this stuff. How 'bout it
peejay.let the wisdom flow.help me out here man...
Old Aug 8, 2002 | 10:39 AM
peejay's Avatar
Old [Sch|F]ool
lol
the front bar is the same. In the back, SAs had an 18mm bar, FBs had a 15mm bar.
Old Aug 8, 2002 | 11:15 AM
RXcetera's Avatar
EliteHardcoreCannuckSquad
The bar diameter was reduced because the SA one was much too thick (stiff) and caused the rear end to bind even more severly than it does on the FB . Many SA's have been converted to the 15mm bar to improve handling, others have simply been removed.
Old Aug 8, 2002 | 11:59 AM
peejay's Avatar
Old [Sch|F]ool
The binding is because the upper links are not the same length or even in the same plane as the lower links. The car can only lean so far and then the suspension binds up. Lowering makes this worse.
A stiffer bar will actually help because it'll help keep the car from getting to the bind-up point. Of course, the car will be an oversteering pig, which is kinda fun if you're expecting it.
Going to a smaller bar or removing it entirely makes it worse, because it makes it easier to get to the bind-up point. Of course, the car will understeer a lot more before that...
The way to fix the binding is to throw away the upper links and go to a 3-link setup (upper link is in the center) or go with a torque arm setup. Then you'll have all sorts of rear-end grip in corners because the suspension can actually MOVE.
Old Aug 8, 2002 | 01:22 PM
MarkPerez's Avatar
Tennis, anyone
Thanks peejay.!
Old Aug 8, 2002 | 03:27 PM
Hyper4mance2k's Avatar
The Shadetree Project
so since i have a fb your saying i should do what??
Old Aug 8, 2002 | 03:55 PM
RXcetera's Avatar
Ask the vast majority of people who have FAST FB's and they will tell you to TAKE IT OFF!
Old Aug 8, 2002 | 04:34 PM
peejay's Avatar
Old [Sch|F]ool
Wusses
Old Aug 8, 2002 | 07:15 PM
MarkPerez's Avatar
Tennis, anyone
What !!?? who are you talking too peejay ???
Old Aug 8, 2002 | 07:26 PM
peejay's Avatar
Old [Sch|F]ool
people who take their rear bars off
i found that UNDERSTEER was my main problem when good tires were on the car... mainly because the front suspension has so little travel that the car pretty much rides on the bumpstop in corners = plow like Farmer John!
THAT can be FIXED though....
Old Aug 8, 2002 | 11:22 PM
MarkPerez's Avatar
Tennis, anyone
Not by installing the -SA stuff ,,right ?? and i hear you,
about the front riding on the stops through corners..
sucks,,no travel,,,vs,,the rear,,a while back,( i'm pretty
sure it was you,,peejay ) posted something about
-SA's sway bars.. I just wanted to know if the -Sa's
were better then the FB's..
Old Aug 8, 2002 | 11:33 PM
peejay's Avatar
Old [Sch|F]ool
They're stiffer. Stiffer does not always mean better. But it is something to keep in mind - if you want a bigger rear bar you can just hit up the junkyard for a '79-80. Or, if you have an SA, if you want a smaller rear bar you can go and grab one from an FB.
Old Aug 9, 2002 | 12:21 PM
mkatz's Avatar
Newbie
what is the best way to do this?
Old Aug 9, 2002 | 12:31 PM
peejay's Avatar
Old [Sch|F]ool
http://www.gforceengineering.net/
I'm not too far from them, I should really stop by for a visit sometime
Jingkun
Sep 28, 2015 01:53 PM
