Amount of $$ needed to get a rx7 into mid 2 low 12s?
Old Aug 7, 2002 | 02:17 AM
I tried searching for this (spent about 1.5hrs doing so) but i could not find a good answer, nor a good set of mods one would need to achieve this? So here I ask, approximately how much money would it take to get a rx7 into like the 12-12.5 range? And exactly what things would be necessary. I am guessing intake, down pipe, mid pipe, exhaust, larger injectors, pully set, larger fuel pump, Power FC, what else? Or maybe you do not need the injectors? I see that at the rx7store.com it has the stage 4 upgrade kit for 3500 bucks and includes these items
Apex Power Intake
Apex N1 Exhaust
Unorthodox Main Drive Pulley
HKS Downpipe
Apex Power FC
Greddy Front Mount Intercooler
Midpipe
Fuel Pump
According to that site that should let me go to 14 lbs of boost, so what ya think is that stuff enough for mid to low 12s?
btw this would be on a no street port, stock turbos engine
thanks
krystian
Old Aug 7, 2002 | 04:10 AM
mazdaspeed00's Avatar
For Sale
ok here is what u need. if u wanna run on stock turbos and a non ported engine.
DP - 200-400
MP or high flo cat - 200-400
CB - 300-600
upgraded ECU standalone is better 1k-1.2k apexi PFC
street/strip clutch 500-600
9lb flywheel - 300-400
FMIC- 1k-2k
intake - 200-500
bigger injectors - 300-400
fuel pump - 200
nitto drags or some sticky hoosiers - 600-1k
pullies - 200-300
the stock turbos shouldent really be boosted above 1 bar but if you dont mind rebuilding them then run as much you want but i doubt that can hold anything more then 20 psi.
u should be in the 12' with this set up add it all up. you can also do things like gut your whole interior to make your car lighter. you can also remove the ac/ps/wiper motor/blades, and air pump.
Old Aug 7, 2002 | 06:32 AM
ttpowerd's Avatar
HARRRRRRRRR
Looks like you got a pretty good idea of what mods you need but you are also going to need to know how to drive it. Most of it is up to how well the driver can perform going down the strip.
Old Aug 7, 2002 | 06:40 AM
user 84205's Avatar
I was just going to say the same thing.....hehe
Old Aug 7, 2002 | 07:13 AM
Wade's Avatar
There have been plenty of FD's run mid/low 12's with only the following:
intake
full exhaust (no cats)
computer
12-13psi boost
pullies (though I don' really know how much these help)
There is really no need for a light flywheel, bigger injectors, fuel pump, or slicks.
Wade
Old Aug 7, 2002 | 08:31 AM
neoamd's Avatar
LS Powered
intake
computer
12-13psi boost
Wade
*not yet*
Old Aug 7, 2002 | 09:17 AM
redrotorR1's Avatar
LS6 Convert
Maybe not slicks, but some decent tires. Don't try and run 12's with crappy all-season tires or some low-brow brand. You'll probably spin them through third gear ...
Putting down that kind of power, you'll want the stronger disc and pressure plate (clutch). The stock clutch will wear out pretty fast under that kind of stress. And while you're in there, you might as well go with the lighter flywheel. And the bigger injectors and fuel pump and for the engine's safety. Better to mod on the side of caution ... unless you like replacing engines.
redrotorR1's Avatar
LS6 Convert
double post
Old Aug 7, 2002 | 10:06 AM
Wade's Avatar
I'm not saying there are not good reasons for additional mods, I'm just saying that is all it takes to run mid/low 12's if someone knows what they are doing and kind drive pretty well.
Also, a lot of mods are arguable as far as "erring on the side of caution"... for example:
Some fuel pumps make fuel slosh problems worse... Power FC loses knock control and appears to be mapped leaner than the stock ECU... Some people question the reliability of enlarged injectors. Etc.
Wade
Old Aug 7, 2002 | 11:35 AM
SPOautos's Avatar
Hey, where did my $$$ go?
Wade is right
With a good strong stock motor and turbos. I ran 12.3 @ 113 with intake, full exhaust, PFC running the base map with 12-13psi of boost. I also ran on some worn out Nitto drag radials and stock wheels my 60 foot was 1.89.
EVERYTHING ELSE WAS STOCK ALL THE WAY DOWN TO THE CLUTCH.......I did however replace the clutch shortly after hehe
STEPHEN
Old Aug 7, 2002 | 11:37 AM
alright thanks for the help
Old Aug 7, 2002 | 12:02 PM
RX7Elmo's Avatar
When it comes down to it you can get an FD3S to run 12s for not that much money. If you buy parts used, you can get a full exhaust for under 600, intake for under 200, and an ECU for anywhere from 400-1000. Throw in a new clutch (500) and some newer REAR tires (300) and some dyno tuning (200) i would say you're ready to go
I really suggest dyno tuning or getting a wideband if you want to make sure the car runs right. You can free up a lot of HP if you have programable ECU as well.
Danny
Old Aug 7, 2002 | 12:51 PM
SPOautos's Avatar
With dyno tuning and all the planets aligned in order with really really really good conditions you could come very close to nailing very high 11's with just intake, full exhaust, Power FC dyno tuned and 14psi of boost. I wouldnt reccomend running that high of boost all the time though cause its borderline with no IC and the stock fuel system. it would prob be ok for 1/4 mile though.
STEPHEN
Old Aug 7, 2002 | 12:53 PM
SPOautos's Avatar
sorry double post
Old Aug 7, 2002 | 03:48 PM
redrotorR1's Avatar
LS6 Convert
Very true. You could also find a different ECU for cheaper that would still give the bump in boost. It's not necessary to go with the standalone. You'll lose some of the tune-ability, but save in the costs. The M2 ECU changes boost to 12 psi, for $700, brand-spankin-new. There are plenty of others as well.
Old Aug 7, 2002 | 04:03 PM
Originally posted by mazdaspeed00
intake - 200-500
[/B]
who the **** makes an intake for $500? i need to get into the intake-making business.
Old Aug 7, 2002 | 04:27 PM
For Sale
u can get a fd running 12's if you run a 150 hp shot of n2o
Old Aug 7, 2002 | 05:16 PM
cash money's Avatar
Old School Member
why would you want lightened flywheel for dragging?
Old Aug 7, 2002 | 05:20 PM
HKS
HKS does http://66.216.67.51/subcatmfgprod.asp?0=214&1=319&2=-1 and yeah i agree with u.
Old Aug 7, 2002 | 05:27 PM
93 R1's Avatar
$1900
See mods below
Old Aug 7, 2002 | 05:44 PM
WhiteRXseven's Avatar
For all of you that replied to this thread.
The question is: Have you run 12's with those
mods you have listed??
And thats on top of your FD running in perfect order.
To many variables to say " such and such " to run
a certain time..
Old Aug 7, 2002 | 06:42 PM
SPOautos's Avatar
I ran 12.3x @ 113 with the advice I gave earlier.
And yes, my car was in perfect order with good compression and good turbos as it always should be if you racing it.
STEPHEN
Old Aug 7, 2002 | 07:26 PM
Mr rx-7 tt's Avatar
rotary sensei
My buddy ran a 12.4 in his viper and I could beat him with just a dp,cat back, 2 K@n's and a boost controller (PFS). Very close but I could slowly pull him ( 97 gts.)
Old Aug 7, 2002 | 07:55 PM
ConfusedPerson's Avatar
93 R1, I find your avatar extremly offensive..A women that beautifull should not be wearing that much close!
Old Aug 9, 2002 | 03:03 AM
M-inent 1's Avatar
STEPHEN
Did you do this time on dr's?
Nice times. BTW
