Can I lower my FD w/ just konis?
Old Aug 4, 2002 | 12:00 AM
SoCalLove's Avatar
I have Konki adjustables on my FD. I have the stock springs on it though. Is it possible to lower my car w/ just the adjustables or should I get coilovers as well?
Thanks.
Old Aug 4, 2002 | 03:43 AM
jupiter's Avatar
if you have the yellow ones.
I think the perch can be lower 1/2"
Depends on how low you wanna go.
If you got the $$$$ get coilovers
maxcooper's Avatar
WWFSMD
Koni's FD shocks are unique in that you can put the lower spring perch on one of three distinct settings. This offers some lowering from the shocks alone, even with stock springs. But you don't get much lowering and it is probably a pain to adjust once the spring is installed. Note that this is in addition to the shock damping adjustment (the two are not related).
I like coil-overs because you get a wider range of adjustment and the range is continuous (infinite number of settings, versus three for the Konis with stock-style springs). They are also much easier to adjust. You can also choose whatever spring rates you want. Ground Control makes a coil-over conversion you can use with your Koni shocks.
There have been a bunch of posts on spring rates and coil-over options, so please search before asking about them. Then ask if you don't find what you are looking for.
-Max
Old Aug 5, 2002 | 11:29 AM
SoCalLove's Avatar
Ahh, ok I get it. So it is possible to adjust the konis. But I won't have a broader range of settings unless I get coilovers. I am planning on getting coilovers sometime in the future, but for now I'd like a simple lowered look to my car.
Thanks.
Old Aug 13, 2002 | 09:18 AM
blackscorpio's Avatar
#1 F0RUM TROLL
I just installed a set of koni yellows and I didnt notice that the height was adjustable. The lower pearch only seem to be able to go in 1 spot. Did I miss something.
Old Aug 13, 2002 | 10:07 AM
DamonB's Avatar
Yep. There are three grooves in the shock body into which you can put the clip the spring perch sits on.
Don't forget everyone that those grooves don't appear to drop the car much but keep the suspension geometry in mind. A small change in perch height ends up being a much larger one at the wheel. You can drop the front and rear about an inch with the lowest perches on the Koni.
Old Aug 13, 2002 | 04:42 PM
If you want just an even 1.25" lowering in the front and rear, you might consider H&R springs with the Koni's set at the top spring perch. I have this on my FD and like it alot. I also think your perch setting will be inluenced by the tire size also.
Old Aug 13, 2002 | 06:19 PM
SoCalLove's Avatar
I'm gunna go ahead and lower my FD now that I've searched a little more and found people using the koni yellows w/ stock springs.
But, I can't find my directions, can anyone tell me how to do this, pleaaassssse?!
ricardo.benin
Sep 22, 2015 12:06 PM
Bill B
Sep 18, 2015 01:36 AM
Ernstudet22
Sep 14, 2015 09:19 PM
