Autometer A/F Gauge not reading right
Old Aug 3, 2002 | 07:31 PM
Swamp RX-7's Avatar
Thumbs down Autometer A/F Gauge not reading right
I've noticed that my A/F gauge is not reading correctly. My Power FC is saying that I'm running @ .85v @ WOT. However my A/F gauge is only lighting up the orange LEDs. According to the booklet that came with the Autometer gauge, the green LEDs should light up starting at .75v. So, when I go to WOT I should see at least two green LEDs light up. Whats going on with the gauge?
Old Aug 4, 2002 | 06:41 AM
grampa's Avatar
The voltage slope on OEM O2 sensors is so steep on either side of stoich that they are little more than on-off switches. Expecting any meter you connect to it to be "calibrated" blindly to the slope is a crap shoot. Different brands will have slighty different slopes and response times. Evey within one brand you will have tolerance issues.
I use my J&S gauge on the OEM sensor just to see if things are basically working or in closed loop. I use a wideband for meaningful data.
Of course this topic has been a beaten dead horse that a search would have yielded a conclusion to approximately the same results as above.
andyvideopro
Aug 20, 2015 10:55 AM
sYnth.
Aug 19, 2015 06:27 PM
