Trouble At Idle...help
Old Aug 2, 2002 | 10:50 PM
letsgetit's Avatar
Newbie
car has trouble at idle, well not trouble, but the rpm needle fluxuates from 1500 rpms. then drops to 500 rpms, then hops right back up or something around those numbers, nothing above, sometimes it may even staul out.......what could it be, does this happen often, thanks......if this helps the car is the 88 aniversary rx7 turbo.
Old Aug 2, 2002 | 10:51 PM
TRURX7's Avatar
make sure your BOV vacuum line and boost sensor lines are in there snug. I had to use a hoseclamp on one of those b/c it kept slipping.
Old Aug 2, 2002 | 10:53 PM
TRURX7's Avatar
this sounds exactly like what happens when the boost sensor electrical plug is disconnected, but there are probably about 6 other things to be possibly checked.
good luck
TRU
Old Aug 2, 2002 | 10:56 PM
letsgetit's Avatar
Newbie
thanks, ill check it out, but this might help even more, theres a greddy boost gauge and boost controller installed in the car, but they are not hooked up at the time, maybe that could be it, im not sure, any more help, i appreciate it
Old Aug 2, 2002 | 11:00 PM
TRURX7's Avatar
definitely sounds like a vacumm line or boost sensor problem to me, if it persists, i would look into blocking off the acv if you havent already done so. I know you have a 10AE but, you can always slap it back on.
hehe
TRU
Old Aug 2, 2002 | 11:04 PM
letsgetit's Avatar
Newbie
ill look into it tomarrow, ill make to post back on what it is, thanks again for the help.
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Rotafuzz
Sep 30, 2015 09:55 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
blackball7
Sep 20, 2015 08:33 PM
WANKfactor
Sep 15, 2015 07:45 AM
