Rear Clunking with Eibach Prokit/Tokicos?
Old Jul 31, 2002 | 10:33 AM
RX7Elmo's Avatar
I posted on the suspension forum, but not much help there...
The combo is tokico 5-ways, eibachs, and eibach sway bars.
I'm goin to be purchasing a car from someone with the above setup but i can hear pretty distinct clunking coming from the rear...most likely the strut/spring combo, as if the springs are moving aroudn? not sure. Is this normal? and if not, what is most likely the problem?
Danny
Old Jul 31, 2002 | 10:54 AM
WhiteRXseven's Avatar
Danny...
Thanks for the Springs..
havn't gotten them in yet..
But the clunking you are probably hearing/Feeling
are the bushings, that probably need to be replaced..
Old Jul 31, 2002 | 10:58 AM
dclin's Avatar
Perpetual Project
Re: Rear Clunking with Eibach Prokit/Tokicos?
Danny
Likely one (or more) of the bushings - common problem. I had to replace every single last one of the them until the clunking stopped. (not to say it was all of them, just did them in groups so not sure exactly which one).
I do know that when I replaced the diff bushings, alot of the clunking went away, so in my case it was a mixture of the diff bushings and suspension bushings.
Old Jul 31, 2002 | 11:05 AM
RX7Elmo's Avatar
whiteRXseven. I'm glad you got them fine. You should be happy with them.
And i went ahead and did a search on this. Turns out it's an $$$ problem. Seems like it's popular to go and get the pettit toe-links and some of the other bushings
Total looks like it will be 500+ ouch! thank god a lot of this is DIY.
Danny
Old Jul 31, 2002 | 11:06 AM
Zach McAfee's Avatar
FTD Wanna Be
It would help if you specify the conditions when it clunks.
-Is it when the suspension is under a hard transition e.g. going up a driveway at an angle? This is possible if the swaybars are out of adjustment.
-Is it clunking under engine speed changes? I'm replacing my diff. bushings in hoping to fix this.
The clunker
Old Jul 31, 2002 | 11:43 AM
RX7Elmo's Avatar
It's mainly clunking over bumps more noticeable at slower speeds.
The car could be in neutral coasting down a hill, go over some bumps and then i hear clunking in the rear. over a pothole, manhole, whatever, makes the same clunk.
It's not the sway bar bushings, and nothing to do with the drivetrain.
Danny
Old Jul 31, 2002 | 11:46 AM
FTD Wanna Be
Aha! Go to the Mazdatrix suspension page. It may be your camber links.
I'll save you the time:
"Stock Rear Camber Links
This (two per car) link goes on the rear control arm, forward, inboard end/pivot. When they go bad, you get an minor, irritating "clunking" from the rear when going over bumps. They seem to wear out most often on convertibles -- must just be the extra weight in the rear?
Rear Camber Links (each) 28-2100-FC01 "
Old Jul 31, 2002 | 12:10 PM
robperri's Avatar
I have a '93 with the same clunking sound at low speeds. Does the 3rd gen have the same Rear Chamber Links?
Thanks, Rob
Old Jul 31, 2002 | 02:42 PM
FTD Wanna Be
Dunno, go to www.mazdatrix.com and check the suspension section for your 3G.
Old Jul 31, 2002 | 02:56 PM
UnSeeN's Avatar
nope the third gen camber links are different i believe
Old Jul 31, 2002 | 07:23 PM
DRAG0NEER's Avatar
jack up the car and see if you can wiggle the rear wheel....if you can then it's probably the rear toe arm and links bushings, there are 6 of them at $50 each
Michael Mansour
Aug 18, 2015 03:13 AM
