seperating the turbo from the housing?
Old Jul 30, 2002 | 05:22 PM
ttpowerd's Avatar
HARRRRRRRRR
How do I seperate the turbo from this housing that holds the wastegate? I have tried just about everything I can think of but it looks just the same everyday. Is there a special tool I am missing, an techniques I should try, anything??? Thanks for the help!
Old Jul 31, 2002 | 03:22 AM
rx7will's Avatar
Hit it with a rubber mallet or tap it with a hammer, try using wd40 or similar. The housing is actually suppose to be able to rotate, but it stuck on there. I took mines apart to peep the wategate to make sure there werent any cracks or anything.
Old Jul 31, 2002 | 05:08 AM
jspecracer7's Avatar
1JZ powered
That's the trick! It's EASIER with two people so one can hold the turbo by the compressor side and the other can hit the housing down. BE CAREFUL when your hitting it with a hammer. I strongly suggest a rubber mallet.
Old Jul 31, 2002 | 06:03 AM
1JZ powered
Originally posted by Dont_Be_A_Rikki
Do not hit it on its side"like trying to pry it off" I have found it is better to hit it like you are rotating the housing. Does this make sense to you? It works real well.
-Rikki
Ryan,
I know what you're saying
Old Jul 31, 2002 | 06:08 AM
ttpowerd's Avatar
HARRRRRRRRR
sorry, it was a dumb question because I tried doing what you all suggested b4 you even responded and it popped right off. Wastegate is ported and turbos are ready for reinstall
Old Jul 31, 2002 | 06:10 AM
1JZ powered
Good stuff Bryan...you're turning into quite a Rotary expert now!
Old Jul 31, 2002 | 06:16 AM
ttpowerd's Avatar
HARRRRRRRRR
haha...is that a good thing? LOL Yeah, I keep running into problems though Check out my post on the m2 ast elimination. Nothing works out for me, nothing!
cristoDathird
28
May 30, 2019 08:47 PM
The Shaolin
Sep 14, 2015 07:50 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
