Any Tips on buying a fc?
Old Jul 29, 2002 | 09:29 PM
Avatar's Avatar
I'm going to look at an imported fc1031 in the next couple of days. Is there anything I should watch out for?
Old Jul 29, 2002 | 11:03 PM
Wankel7's Avatar
Haven't we ALL heard this
Not sure what a FC1031 is.....however.
Do a www.carfax.com check and do a compression test.
James
Old Aug 13, 2002 | 10:54 PM
Avatar's Avatar
cheers
FC1031 is a series 4
Old Aug 13, 2002 | 11:10 PM
If it's an s4 you should check the chlutch & brake master cylinder for leaks (feel underneath drivers side carpet, sometimes leaks through firewall), slave cylinder for age and leaks. When you take it for a ride leave the stereo off so that you can here for things like bad differential mounts and other bad suspension componants. Also check the boost lines and other rubber hoses for pliability(no hard as plastic) and to see if there are any leaks(fluid or air). Check boost pressure and vacume pressure if possible. I think that just about covers it.
Old Aug 13, 2002 | 11:43 PM
TheBigOne's Avatar
In regards to brake master cylinder and clutch:
Was this a common problem with the s4 TII???
Is it just the entire clutch system or clutch components like the slave cylinder and clutch master cylinder???
Old Aug 13, 2002 | 11:49 PM
J-Rat's Avatar
Alcohol Fueled!
Originally posted by Avatar
cheers
Thats news to me. I thougt all secoond gen RX-7s were FC3s.
Old Aug 13, 2002 | 11:54 PM
Big One the early fc3s(86-88) all had problems with thier hydraulic systems. It has something to do with the construction of the stock componants. Usually if you get a part that's not OEM it will solve the problem. Tokico sells some good stuff if you want to pay that much to stop or shift your car.
Old Aug 14, 2002 | 08:38 PM
Avatar's Avatar
Mazda Australia lists the models as Fc 1031 for s4 and FC 1032 for s5. Figured it would be the same world over.
Old Aug 14, 2002 | 09:37 PM
Evil Aviator's Avatar
Rotorhead
Buying an FC:
http://www.aaroncake.net/RX-7/
VIN decoding:
http://mrmazda.members.atlantic.net/mdictionary.html
Old Aug 14, 2002 | 10:58 PM
J-Rat's Avatar
Alcohol Fueled!
Hmm..Not that its a big point or anyting, but all FCs here are FC3s.
Rat
Old Aug 15, 2002 | 01:47 AM
Avatar's Avatar
Thanks for your help guys, with any luck I'll own one SOON
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
jdayau
Nov 29, 2019 12:11 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
