What parts needed to put gsl-se rear into a 1980???
Old Jul 29, 2002 | 12:51 PM
DoceA's Avatar
Question What parts needed to put gsl-se rear into a 1980???
Ok. I ordered the stainless steel brake line kit for "79-80 rx7 w/ 81-85 rear disc". I will soon be getting the entire rear from a gsl-se. This includes rotors, calipers, and emergency brake cable.
My question is: Do I need any other parts to make this conversion? I know that the gsl-se bolt pattern is different, so that problem doesn't need to be addressed. But is there anything else I need to get? Thanks.
Old Jul 29, 2002 | 01:00 PM
abeomid's Avatar
well since you know the bolt pattern is different, you probably know already that you have to redrill the rotors or change the axles and rear diff as well
Old Jul 29, 2002 | 01:15 PM
DoceA's Avatar
you lost me abeomid,,,, i'm putting in the entire gsl-se rear into my 1980,,, differential and all....
Old Jul 29, 2002 | 03:12 PM
abeomid's Avatar
oh sorry, i only saw the rotor and caliper part , if you have the brake line, u should be fine. I'm almost certain that the driveshaft will bolt on there as well, anybody wants to second that??
Old Jul 29, 2002 | 04:09 PM
riffraff's Avatar
smog nazi destroyer
the driveshaft will not bolt up.. you will need to get that as well
Old Jul 29, 2002 | 04:10 PM
Hyper4mance2k's Avatar
The Shadetree Project
Exclamation
okay i've got an '83 i want to put a posie in my car i know of a gsl rear end i could get please tell me everything i would need to do the switch over. and did the gsl have 110mm or 114mm?
Old Jul 29, 2002 | 05:07 PM
peejay's Avatar
Old [Sch|F]ool
Posi = Chevy garbage
GSL gas 110mm. GSL-SE has 4.5" (114.3mm).
Old Jul 29, 2002 | 05:30 PM
Pedestrian X's Avatar
SpAz!
wow peejay, im starting to notice you have a THING against chev's? hehe ohwell. but didnt the gsl rear ends have limisted slip not posi?
Old Jul 29, 2002 | 07:37 PM
riffraff's Avatar
smog nazi destroyer
limited slip is more or less the same thing as posi.
Old Jul 29, 2002 | 08:19 PM
peejay's Avatar
Old [Sch|F]ool
Posi and Positraction are Chevy's "brand name" for limited slip.
Old Jul 30, 2002 | 12:11 AM
Magnus Berglund's Avatar
I put an 84 (gsl-se with lsd) axel on my 81 car..
It fits rellay well! No need to modify anything really...
Just bolt on..
That was the complete axel... all of it.
//Magnus
Old Jul 30, 2002 | 03:47 AM
Manntis's Avatar
add to cart
I think roror-lynn is doing or has done the same. She might be able to offer some advice
Old Jul 30, 2002 | 06:58 PM
rotor-lynn's Avatar
I'm putting '84 SE suspension in an '85 S. The axle is a straight swap but you also need the e-brake cables and the master cylinder/proportioning valve from a rear disc car.
See www.mazspeed.com/axel.htm (it's not a typo) for axle differences between years.
I do have definitive information on the differences between the front dampers on a 12A and 13B.
No difference in spindle
13B spring perch is 1/4" higher
13B total height is 1/4" taller
Difference in the radius of a stock 12A 185/70/13 tire vs stock 13B 205/60/14 tire: about 1/4".
Damper/spindle measurements may not apply to 81-83 cars since it and some of the front wheel bearing part numbers are different from 84-5's and I didn't have one to check with my calipers.
Old Jul 30, 2002 | 07:07 PM
so i neeeeeeeeeeeeeeeeeeddd??????
a simple list of parts would help me thanks
Old Jul 30, 2002 | 09:33 PM
rotor-lynn's Avatar
Check out the site I listed.
It depends on the year of the donor car also.
jase03
Aug 20, 2015 02:09 AM
