ignition setups
Old Jul 28, 2002 | 06:32 PM
rotary88n00's Avatar
ignition setups
I know that you can add an msd ignition to an 88 NA. I also know that you need two boxes and it is like seven hundred almost for the whole set up. Does anyone know how it compares to the jacobs ignition setup for like three and change.
Also is it needed with a street ported 13B with full exhaust, port and polished intake manifold, and 720cc injectors.
Old Jul 28, 2002 | 09:17 PM
bcty's Avatar
Boost This!
its not needed.. but always recommended with the more mods you do.. i would save up and get the Jacobs.. it is better stronger and made for the rotary. i have heard not one bad thing from it.. and the whole setup should cost you around $700.. unless you are buying 2 MSD boxes for the leading and trailing!
Old Jul 28, 2002 | 09:19 PM
bcty's Avatar
Boost This!
sorry i didnt read the whole post... you dont need 2 boxes.. most ppl just put them on the leading plugs and that is good enough
Old Jul 29, 2002 | 07:32 AM
silverrotor's Avatar
So, does anybody have them on both Leading and Trailing? How has It worked for you/them?
Old Jul 29, 2002 | 09:27 AM
BiG WaNkLeR's Avatar
I heard it can get expenisive as you need one on the leading and 1 each on the trailing
Shainiac
Jul 17, 2019 02:20 PM
ncds_fc
19
Sep 15, 2015 12:03 AM
