What are common problems with Fc's?
Old Jul 28, 2002 | 05:48 PM
List some common problems, and maybe specific problems with certain years. Thanks
Old Jul 28, 2002 | 06:14 PM
Rxmfn7's Avatar
Do a barrel roll!
Most have little eletrical bugs, nothing major just enough to annoy you. Stuff like clock, windshield wipers, warning lights, power window switches..... Some would say that flooding is a common problem, although mine has never done it.
Old Jul 28, 2002 | 07:12 PM
black7's Avatar
A lot of the electrical problems with 86-88 were fixed in 89-91s but not everything. 86-88 more likely to flood than the 89-91. Most if not all FCs have broken interior pieces but that is expected with a 14 yr old car.
Old Jul 28, 2002 | 07:14 PM
thermal pellet, old bushings, u get an old car that comes with old stuff on it
Old Jul 28, 2002 | 07:42 PM
sir_sun's Avatar
everything
idle problem
clock
wiper
light
window
sunroof
overheat
Old Jul 28, 2002 | 11:23 PM
What do you do when it floods? Mine did it the other day
Mario
Old Jul 29, 2002 | 01:37 AM
Funklord's Avatar
when it floods, go under the hood and pull out the EGI fuse, then crank it for a bit (your car will not start) then go put the fuse back in, and you're good to go. i wired a switch up to it so i dont have to go under the hood to pull the fuse, i just hit the switch
Old Jul 29, 2002 | 01:57 PM
john's Avatar
how do u knoe when the car floods out
Old Jul 29, 2002 | 02:05 PM
SureShot's Avatar
Seduced by the DARK SIDE
The starter cranks faster than normal & fuel smell from exhaust..
Old Jul 29, 2002 | 02:48 PM
Icemark's Avatar
Biggest problem common with many FC's????
The owners that think they need OHV piston engines
Just kidding...well actually no, not kidding too much... the biggest most common problem with FC's is owners that don't maintain them properly and then complain about the car always being broken, or they just sell the car and whoever buys it gets stuck fixing all the things that should have been taken care of as maintenance, but now are major problems.
Old Jul 29, 2002 | 02:52 PM
SlitheryImp's Avatar
The only thing that really irritates me is that damn sticky sunroof, has anyone got a good fix for it, or should I just accept it?
(no, I haven't pulled the thing apart, sort of worried I won't be able to put it back together, I don't have a garage :-( )
Old Jul 29, 2002 | 03:18 PM
attomica's Avatar
Only problem I've ever had is the power antenna.
Old Jul 29, 2002 | 03:31 PM
brap brap
What does your sunroof do, slitheryImp? Mine had a problem a couple weeks ago - she's better now. I had to manually closer her.
Hmm...problems I found?
idle
clock - only has worked with correct time..... once!
passanger side window - switch doesn't work anymore.
alarm system - every now and then, it'll stop working.
Hm, that's it.. I suppose, for now... that I can think of.
Old Jul 29, 2002 | 03:45 PM
BDoty311's Avatar
88 AE
Yes I would agree that electrical problems top the list of things that go wrong with the FC. I am dealing with a clutch pedal that likes to stick in the down position. Ive adjusted the pedal pressure and WD40'd it and it still sticks. Any suggestions??
Old Jul 29, 2002 | 06:58 PM
Snrub's Avatar
All of the bolts will break or strip threads....I've done Intake manifold (2x), twin scroll actuator 87 & 88 (2x), undertray (5x), hood stand and probably some others. All a function of age, not the car, but it's irratating none the less.
Old Jul 29, 2002 | 09:06 PM
SaabGuy's Avatar
Wiring harness gets hard like a *****
Old Jul 30, 2002 | 01:03 AM
Icemark's Avatar
replace the clutch master cyl.
Old Jul 30, 2002 | 07:45 AM
Cheers!'s Avatar
Former Rx7 *****
do u need to drop the tranny to get to the clutch master cyl.? my squeeks a bit and i ahve problem disengaging reverse... if its in reverse and it gets to the point where its real difficult to disengauge it, and put the clutch all the way in... rpms will drop to around 500... and car will almost stall.
Old Jul 30, 2002 | 09:38 AM
rx-7fc's Avatar
no you do not need to drop the tranny to get to the clutch master
Old Jul 30, 2002 | 09:39 AM
rx-7fc's Avatar
all you need is a 12mm
Old Jul 30, 2002 | 10:05 AM
BDoty311's Avatar
88 AE
i bled the clutch fluid and it seems to be better, but I'll have to see how it holds up on the long drive to work.
Old Jul 30, 2002 | 10:13 AM
ZachSpazz's Avatar
I wish I had a posse...
HAHAHAHA!!!
Old Jul 30, 2002 | 01:03 PM
Taranis's Avatar
No. Master Cylinder is on driver's side top, right in the corner. Follow the lines coming out of it to the clutch slave cylinder. 2 nuts under the dash and the Master's out, 2 bolts on the bell housing and the slave's out.
Replace and bleed both and you're done.
Recommend you replace both slave and master at the same time. My problem was exactly like yours, but it was the slave that was the culprit.
JB
Old Jul 30, 2002 | 02:43 PM
To open the sunroof I have to push the button, push the sunroof, and then push the button again, not really a big deal, it's just a bit irritating.
I think I'll just pick a nice day and pull the thing apart, if I can't put it back together on time, I'll store it in my fathers' garage, or tape a garbage bag over the hole
Old Jul 30, 2002 | 03:54 PM
Aaron Cake's Avatar
Engine, Not Motor
http://www.aaroncake.net/rx-7/buy1.htm
