does anyone use a shift lite?
I have one... NOT one of those huge Monster gauges which shift light, I have a pivot shift lamp, tapped into my computer...
I think its very needed if you drag... Its not set just for
your redline, its set for your power band... Well I guess depending on which one you get....
Jason
www.jt-imports.com
Jason
www.jt-imports.com
1JZ powered
Originally posted by BoOsTin FD
I would also like to know where do you hook it up, or which wire do you tap it in in the ecu?
Thanks
Thanks
This is a copy and paste from Robinette's site:
Connect the tach wire to the negative wire of one of the two trailing coils. I used the #2 trailing coil (nearest firewall) and tapped into its blue and yellow wire. Set the tach’s cylinder setting to 4. Using this method my shift light would illuminate at two times the setting of the light, it was set for 3000 rpm and the light goes off at 6000 rpm so I set the light for 3600 rpm and now the light goes off at 7200 rpm.
I know that you can also tap into the tach signal from the Diagnostics connector, but I don't know which terminal to tap into.
Originally posted by Kraziken
Is it really necessary in the FD?
I always thought the Audible "BEEP" as you were in the redline was good enough.
I think it is better and less gaudy as a shift light.
Trending Topics
Originally posted by RICKRX7
I have a hard time hearing the buzzer W/ Dp & RB cat back. I would think the guys w/ full exhaust could not hear the buzzer at all.
Originally posted by jspecracer7
You mean for a shift lite? Or a tach?
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
