Wheels!
Old 12-11-03, 11:18 PM
Manolis_D's Avatar
Wheels!
I whipped up a wheel in SolidWorks today - It's about 18-19" in diameter (19.xxx to the outside of the lip). Thought some of you might enjoy it.
Old 12-11-03, 11:21 PM
Manolis_D's Avatar
Another view!
Old 12-11-03, 11:26 PM
Manolis_D's Avatar
One more...
Old 12-11-03, 11:40 PM
Manolis_D's Avatar
Front shot
Old 12-12-03, 12:14 AM
Manolis_D's Avatar
front shot
Old 12-12-03, 12:27 AM
Manolis_D's Avatar
estimated weight in aluminum is 31lbs (whoops! i'll have to play around with it some more ), and the max side loading is ~4.7g's (not enough -- needs work)
estimated weight in magnesium is 19.75lbs (now we're talkin'!) and the max side loading is ~11.5g's (that should be fine)
Interesting
-Manolis
Old 12-12-03, 07:51 AM
Brian7's Avatar
Thats crazy.. Cool shi*.
Old 12-12-03, 07:55 AM
Lava Surfer
bingoboy's Avatar
fix the weight and i will test them for you
Old 12-12-03, 09:31 AM
not sure anymore
pinkfloyd's Avatar
little more deep dish action would be nice but that is some cool ****
Old 12-12-03, 02:24 PM
you are missed
nillahcaz's Avatar
not a bad thing but it looks like the Enkei rc5 specs
me im more of a prf1 guy.
Old 12-12-03, 02:44 PM
Manolis_D's Avatar
Wow those enkei's are similar - surprising, because I just did that 'free hand' Too bad they don't come in the right bolt circle.
Here's another shot of the wheel with a few little details changed. It's about 30% stronger and 1lb heavier. Now to make the spokes hollow
Old 12-12-03, 03:11 PM
Manolis_D's Avatar
Old 12-12-03, 03:15 PM
Manolis_D's Avatar
Old 12-12-03, 04:25 PM
not sure anymore
pinkfloyd's Avatar
sweet...i like yours a lot more then the rc5's.....i cant wait to see it when you are totaly done and photo shop it on some 7's
Old 12-12-03, 05:12 PM
WingmaN
Scalliwag's Avatar
That is bad *** dude!
Old 12-12-03, 06:23 PM
Rob
wanklin's Avatar
very classic, nice work.
Old 12-13-03, 09:20 PM
Manolis_D's Avatar
More tinkering!
I made a slightly different design today. This model allows me to set the offset, change the radius (curvature) of the spokes, change the diameter, and change the depth of the lip. Weight for the wheel (17x9.5) is about 17.5lbs. If anybody knows how to use FEA / help me calculate whether or not it'll fall apart, let me know . Let me know what you think
Old 12-13-03, 09:32 PM
Manolis_D's Avatar
Here's the backside of the wheel, showing some of the reliefs i put in there (they drop weight about 3 lbs). I got another 3 lbs off by cutting out a some of the rim where the spoke meets up with it.
Old 12-13-03, 09:34 PM
Manolis_D's Avatar
rim relief
Old 12-14-03, 03:31 AM
PV = nRT
clayne's Avatar
Make the whole thing out of tungsten and call it a day.
Old 12-14-03, 03:37 AM
i once made some rims myself, check em out
copies of axiss se7en 3 piece
Old 12-14-03, 05:56 AM
moprblms's Avatar
hey what program are you using to make your desiens?
Old 12-14-03, 01:27 PM
Manolis_D's Avatar
Hey M5150 - what program did you use to render that -- looks great!
moprblms - I used SolidWorks2003 for the drawings
Old 12-14-03, 02:23 PM
Rob
wanklin's Avatar
did you use this same program to calculate the weight, strength etc?
Old 12-14-03, 08:23 PM
Manolis_D's Avatar
Yep! Solidworks lets you input a density for the material you're using, and calculates weight off of that. The strength analysis program that solidworks uses isn't ver good though -- I'm going to have a friend run some numbers with another program to see what it comes up with.
As a bit of a side note, the wheels would be about 12.5 lbs (for a 17x9.5" wheel!) if made out of magnesium, and they'd be stronger too
-Manolis
Quick Reply: Wheels!
