Running too rich?
Old Jul 25, 2008 | 03:41 AM
FirstFC's Avatar
Unhappy Running too rich?
ok i got this 1991 rx7 that i need help with. The problem is the car is running super rich, so rich that it will shoot flames out the exhaust by just pressing the gas pedal. Also if you try to floor the gas pedal the car would bog immensely and wont go anywhere, but if you lightly tap the gas it would build revs. you can smell the gas coming out and a ton of smoke. Things we tried: Replaced MAF, checked for vacuum leaks, checked injectors one has a crack on the housing but will replace soon, thats about it. I know there is a check engine lights thats on but the dummy lights work when they want to so i cant run the codes. Is there a way to check the codes besides counting the check engine light flashes? besides using a diagnostic computer? The video shows in the beginning i'm flooring it and revs wont go nowhere, it just bogs, than you can see the revs go up when i'm tapping the gas, sorry no sound. http://www.youtube.com/watch?v=_UTQ_S4IdtQ
Old Jul 25, 2008 | 08:53 AM
arghx's Avatar
rotorhead
check your TPS
Old Jul 25, 2008 | 09:30 AM
mazdaverx713b's Avatar
Have RX-7, will restore
have you checked the timing?
Old Jul 25, 2008 | 10:40 AM
Chuck's Avatar
My 1st RX7 was a '91 N/A - white. The exhaust would turn the rear bumper black! I replaced the O2 sensor and the problem went away. That might not be all of your trouble, but it might help. If you're really brave (and desperate) to resolve an over-rich situation, try adjusting the variable resistor. Word of caution: before you do, mark its original position so you'll know where you started.
Old Jul 25, 2008 | 11:16 AM
SDrotary-FC's Avatar
@ pipnorcali
sell it to one of these ricer kids who want flames coming out of their exhaust
Old Jul 25, 2008 | 02:26 PM
ericgrau's Avatar
Clean.
Running too rich, air pump isn't delivering air to the exhaust or timing is retarded way too much.
Old Jul 25, 2008 | 02:44 PM
FirstFC's Avatar
first whats tps?
timing is good
tomorrow ima check compression but i dont think its that...because today we pinched the fuel line because the engine was flooded then let it run with the line pinched and a crazy thing happened I GOT ALOT MORE ACCELERATION...any ideas?
Old Jul 25, 2008 | 02:51 PM
Romancer's Avatar
Ready.Set.Gone
Slow down and share the wealth!
Old Jul 26, 2008 | 02:25 AM
FirstFC's Avatar
what you mean?
Old Jul 26, 2008 | 02:28 AM
FirstFC's Avatar
what you mean slow down and share wat wealth?
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
Jun 26, 2016 10:21 AM
86glxNA
Aug 22, 2015 08:54 PM
