Water found inside the car - passenger side floor
Old Jul 2, 2007 | 08:25 PM
RE-Mamamia's Avatar
Feed me fake Feed
What can possibly cause water to get in??? I lifted the passenger side floor mat and the carpet is very wet with water...what the heck??
Old Jul 2, 2007 | 08:30 PM
NeoTuri's Avatar
The shy megalomaniac
Water or coolant?
Old Jul 2, 2007 | 08:31 PM
ObliqueFD's Avatar
My guess is that your heater core developed a crack and is now leaking coolant.
Another possibility is if you have a sun roof there is a drain line that could be clogged and is letting water in. Pull your passenger side A-pillar to see if it is clogged.
And yet another possibility is a bad seal in your windshield allowing water to come in, but I don't think there would be as much as you described.
Old Jul 2, 2007 | 08:39 PM
Mdessouki's Avatar
There is some type of drain or random hose on the bottom of the AC unit in that area. Check that first.
Old Jul 2, 2007 | 08:40 PM
RE-Mamamia's Avatar
Feed me fake Feed
it's water for sure. I'll pull the passenger side a-pillar and have a look-see tonight.
Old Jul 2, 2007 | 10:33 PM
derrik504's Avatar
fixin to fix it
i had the same problem. I pulled all the interior out and had someone put a water hose all over till i found where it was coming from.the door handal was loose
i tightened the screws and i have'nt had a leak since.i would check the screws first. then try the water hose.
Old Jul 3, 2007 | 02:17 AM
Narfle's Avatar
Rx7 Wagon
There are some AC related hoses up in the very front of the passenger footwell. One of them is likely loose and guilty.
Old Jul 18, 2007 | 02:35 PM
RE-Mamamia's Avatar
Feed me fake Feed
ok, i just washed my car yesterday and the water came back. apparently, the water is dripping down from somewhere above/near the glove compartment. Everything on the outside seems to be sealed pretty good...what do you guys think?
Old Jul 18, 2007 | 02:39 PM
Prometheus's Avatar
Still got it.
Maybe if you have a sunroof, it may be dripping down the Pillars through the dash to the floor...
just a thought.
Old Jul 18, 2007 | 02:41 PM
Sprockett's Avatar
Former Rotorhead
AC probably. Are you using the AC? I don't know what malfunctions in it to cause this, but I do remember a friend's Pontiac Grand Prix having that problem and having it diagnosed as the AC. We got in it one day, and the whole passenger's side floor was drenched. It was water, too...not coolant. All over the passenger's floor. It was fixed at the dealership, and the problem went away.
If it's not the AC, maybe your car has a leak somewhere? Did it rain before you noticed this? You said it came back after you washed the car...did you wash the engine bay too? Maybe there is some place that is not water-tight and water from the outside is getting inside?
Old Jul 18, 2007 | 02:48 PM
darkside7's Avatar
check your a/c drain hose.
Old Jul 18, 2007 | 03:30 PM
preludesh2000's Avatar
i just read though this folder full of papers (from when i bought my car)
the previous owner had this problem...
some dealership fixed it ....said it was the sunroof drain hose...
good luck
brad
Monsterbox
Jul 29, 2022 10:48 PM
Ninja636
Aug 19, 2015 01:52 PM
