Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Discussion; Are aftermarket ECU's that work with an O2 Sensor superior?
Old Apr 21, 2007 | 05:29 PM
DriftTrix's Avatar
Get Sidewayz
Each ECU system has strong points, no doubt about that, some are easy to tune, others have features that allow you to control additional aspects of the car.
I have an Autronic SM4 and it has a lot of great features, ease of tune, and auto calibration with use of the Autronic gas analyzer, a lot of additional controls but I almost feel like it lacks some important controls.
After buying it I was told it couldn’t be connected to an O2 sensor for additional on the fly tuning adjustments like you find on every car 80's and newer. It may not be necessary but I imagine that engines are always changing, be it greater compression from carbon build up on the rotor surface, air humidity, loss of compression from minute scrapes on rotor housings...... etc.... An ECU would be superior in my mind if it could make small adjustments to the amount of fuel it injects based on the current A/F ratios at your down pipe. Right?
It’s kind of obvious how an oxygen sensor or three makes a big difference on how newer cars perform, when a car has 150,000 miles and the 02 sensor is completely covered in carbon and cant take accurate readings its apparent that the car is running bad. Once replaced it performs a lot better but maybe this is just because of the ECU’s dependence on the 02 sensor. To my knowledge it only makes small temporary modifications to the fuel maps with a general map that never changes.
How many aftermarket ECU’s put into the FD use the O2 sensor? I imagine the Apexi ECU is at least hooked up to it but does it use the sensor?
I may be naive and just not know how to hook up my ECU to a 02 sensor so don't beat me down too bad if I just missed something stupid! Just let me know!
Old Apr 25, 2007 | 03:29 AM
a7r's Avatar
a7r
Who told you that? The SM4 can use a variety of narrow and wide band O2 sensor setups to perform closed-loop AFR compensation. One option is to get an Innovate Motorsports LC-1; just hook it up to your ECU according to the manual. Your dealer should be able to answer these types of questions for you.
Old Apr 25, 2007 | 02:01 PM
DriftTrix's Avatar
Get Sidewayz
Closed-loop AFR compensation is self adjustment without the use of a laptop (no human interface)? ... My autronic dealer was the one who told me it couldn't be done...
Old Apr 25, 2007 | 05:10 PM
a7r's Avatar
a7r
Yes, closed-loop fuel trim using the O2 sensor. What version is your ECU's software?
Old Apr 26, 2007 | 12:28 PM
DriftTrix's Avatar
Get Sidewayz
Opening the Autronic computer software I notice PC Software Version 5v26
The Firmware on my base cal file is SM4-1.03
I don't see something that says ECU version .... Let me know if it's on the ecu sticker, i just dont see a version unless its that firmware number.
I'm going to get a LM-1 by plugging it into the computer does it automaticly start close-loop calibration or is there a setting i must turn on?
I have the autronic manuel I can read though, thanks for the tip that it can be auto calibrated, I couldnt understand why my $2,000 ecu wouldn't do that.
I take it the closed-loop calibration compares numbers with my Target A/F map, I'll talk to my tuner and ask him if this map is accurate and ready to go.
Old Apr 26, 2007 | 12:52 PM
a7r's Avatar
a7r
1.03 is an older ROM, you probably need to upgrade to 1.06 in order to do closed loop. Instead of the LM-1, I'd recommend you get an LC-1 instead, and leave it in your car all of the time. You'll need to wire one of the WBO2 controller's analog outs into the SM4, and make sure that the SM4 is configured to read an O2 sensor on that input.
Old Apr 27, 2007 | 12:30 PM
DriftTrix's Avatar
Get Sidewayz
Wow, very helpful thank you.
SMC Mode Flag Setup Ver 1.06
Find mode flag settings for triggering, spare injector and Auxiliary outputs, plus anti-lag for SMC 1.10, 1.18, 1.90, 1.91 and 1.92. ModeFlags.zip (176 k).
You woudn't happen to know if this is the file to update the SM4? I'm going to talk to my dealer and see if he can get that update for me.
Old Apr 27, 2007 | 08:33 PM
a7r's Avatar
a7r
No, that is for the SMC, which is a different product. Your dealer should be able to tell you what combination will work for you. If you can't get an answer, then call up Enzo in NY.
befarrer
Microtech
Aug 22, 2015 05:52 PM
