Power Window Regulator Cable Rebuild Job
Old Dec 7, 2005 | 06:57 PM
Mombodogs's Avatar
FINALLY , I THINK, FOUND A WAY TO SHARE THIS. ENJOY, AND HOPE THIS HELPS. ASK ANY QUESTIONS, PLEASE!
http://www.flickr.com/photos/mombodogs click on either set, both apply
http://www.msnusers.com/powerdog click documents click on power window rebuild
PEACE THE DOG
Old Dec 8, 2005 | 10:21 AM
jackhild59's Avatar
Rotary $ > AMG $
Nicely done!
I couldn't get it to view properly in Firefox browser, but Internet Explorer worked great.
BTW, referencing the #10 pic, last pic on first page, labeled window guide/slide: the upper guide/slide in the pic was simply worn away on my regulator. I believe that the slack created after the part broke caused my cables to bind then break. I replaced the upper slide with a pulley from a manual crank RX7 window regulator. It worked great. If I ever take the door panel off again, I will send you a pic of it.
Old Dec 8, 2005 | 12:10 PM
SureShot's Avatar
Seduced by the DARK SIDE
It's easy to load the cable:
With one hand you hold the gearbox.
With your second hand you rotate the spool to take in the cable.
With your third hand you control & feed the cable.
With your fourth hand you take a picture..
Old May 16, 2008 | 11:46 PM
rotary#10's Avatar
Vodak
WHY isn't this a stick
why haven't the admins and mods
STICKY THIS is so useful. to folks who have pwr windows !
BUMP for good right up i have a 91 FC n/a that has a drivers window thats stuck up it used to go up and down very slowly but i might have to check the switch contacts again and window related parts and same thing with the passager side it goes down fast but comes up slow...
Old May 17, 2008 | 05:01 AM
RETed's Avatar
Thank you for the almost 2 and a half year resurrect...
Mombodogs got banned or something a few years ago.
-Ted
Old May 17, 2008 | 03:57 PM
rotary#10's Avatar
Vodak
can this still be sticky'd ?
Old May 17, 2008 | 04:00 PM
rotary#10's Avatar
Vodak
its to bad someone couldn't combine the info here and rebuilding the window motors n cleaning the track n stuff like that and put it all in one forum and would be super handly and could be under the 2 gen FAQ.. but iono how u folks work. so ima just keep look and hope that someone will come up with something thats more simpified.
