Little question for my transverse project
Old Mar 21, 2006 | 02:20 PM
bart_heemskerk's Avatar
Bart
I am building a transverse setup using a 12A and a toyota transverse transmision. All this must power a 1981 matra murena which is a little french sportscar with the engine in the back. Much like a fiat X1/9.
Engine and transmision are connected, but there are still plenty problems to solve. The biggest is the driveshaft which runs alongside the engine.
I have to make a bearing block for this driveshaft. It must be located very close to the oil outlets.
The plan is to make a bracket attached to the front engine mounts. This bracket runs to the side. At the end an other piece of steel is attached. This piece of steel will hold the bearingblock.
And here is my little question:
I want to mount the bracket to the front housing. Can make a treated hole here and here? Or will oil or water pour out?
Old Mar 21, 2006 | 04:08 PM
Crit's Avatar
No distributor? No thanks
Well, you're in the front iron there rather than the housing. It's almost dumb luck whether or not you'll hit the water jacket. You can go into the front cover, though, without doing any real damage. I'd go to a junkyard with a breaker bar, drop a 12A out of a 1st-Gen RX-7, get the front nut off, and take off the front cover to mess with. You can even pull the flywheel off and take out the tension bolts, and go home with the front iron. I wouldn't risk it on a functional, assembled block, though.
Old Mar 21, 2006 | 07:12 PM
RXDad's Avatar
I went and measured my front cover. At where you want to put the top mounting bolt, you have just a little over 1/2 inch before hitting the water jacket. The bottom has just a small amount more. Don't know if this is enough for what you want to do. My guess is that if you are extremely careful you have a chance to make it work.
RXDad
Old Mar 22, 2006 | 11:34 AM
rxtasy3's Avatar
actually, the car frame should be the mounting point for this axle bearing, not the engine block. is there more to that axle that goes out to the wheel? when the engine torques up in the rubber mounting, that axle will move with it. not to mention what could happen once u tach it up and dump the clutch. not to put a damper on ur plans, but manufacturers don't mount drive axles to engines for a reason.
Old Mar 23, 2006 | 01:52 AM
Jeff20B's Avatar
Lapping = Fapping
I thought about doing a transverse project myself. One of my conclusions was to maybe rotate the engine a little to keep the CV shaft away from the exhaust. Good luck.
Old Mar 23, 2006 | 12:54 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
You mean like this?
Old Mar 23, 2006 | 02:10 PM
Crit's Avatar
Well yeah, but that's just powering a Radio Flyer. I doubt it's indicative of how a car manufacturer would do it...
Old Mar 23, 2006 | 02:25 PM
MikeLMR's Avatar
'Last Minute' Rallying
yes they do, in fact a lot of Mazda fwd cars use nearly an identical system !
Take a look at Mazda protege with an 1800DOHC engine ... you will find the passenger side driveshaft has a bearing on it already (bolted to the block)
Old Mar 23, 2006 | 02:30 PM
MikeLMR's Avatar
there you go ... from the Mazda workshop manual
Attached Thumbnails Little question for my transverse project-driveshaft.jpg
Old Mar 23, 2006 | 02:46 PM
Bart
Thanks guys, I'll go the safest way and find me an front iron. There are not much rx-7's her to find on scrapyards, but i'll find one.
Drilling in the front iron seems to be more tricky then i thought, but it is nescessary to get a solid mount for the bearing.
I am very curious how others have done it on there FWD honda civic or 323.
Old Mar 23, 2006 | 03:33 PM
edmcguirk's Avatar
Cool.
How did you adapt the transmission to the engine?
Is the thickness of the adaptor plate a significant consideration when mating the transmission input shaft to the flywheel? And also the starter motor?
Which clutch and flywheel will you use? Can you get away with just an Rx7 flywheel and pressure plate with a Toyota clutch disk? Would the Toyota starter motor work with an Rx7 flywheel?
The MR2 transmission is supposed to be the same as the Solara except the shift linkage is moved to the front of the engine. Do you think running cables to the shift linkage on the back will be difficult to set up? Or will you drill the transmission and move the linkage to the front? A few people on the MR2 forum have used the Solara trans in the MR2 with this mod but I don't know how difficult it is.
For the driveshaft bearing, one alternative to drilling holes in the engine might be to extend the transmission adaptor plate and create a framework around the engine to the front engine mount.
Good luck
(try to get more ambient light and less flash if you post more pictures)
Old Mar 23, 2006 | 06:30 PM
rxtasy3's Avatar
thanx for the correction guys. considering the only front wheel drive vehicles i've delt with have been Chevrolet, that's what i was going by.
Old Mar 24, 2006 | 12:13 PM
Wankelguy's Avatar
lol, that wagon has had it's share of rotary engines in it.
I actually had a "rotary wagon" emblem from an RX4 wagon that I was going to mount on it, but I ended up selling it for like $45 on eBay.
That's a Fiesta motor that was turbocharged BTW.
Old Mar 24, 2006 | 12:16 PM
Wankelguy's Avatar
Oh, and why not just weld a bolt to the header flange for the upper mounting point?
Old Mar 24, 2006 | 01:46 PM
Bart
That way you bring a lot of stress in the material.
I used a transmission of a toyota celica (=solara?) with a 3sge engine. I need the gear linkage at the back and a mr2. I connect the gearlinkage not with cables, but with the original levers of my car.
The 12A (manual gear) flywheel is pretty big. To big to fit in the original bellhousing of my car. The toyota gearbox has a big bellhousing.
I didn't want to do it with a counterweight of a automatic 12A and fit an other flywheel. These counterweights are rare in europe and i cannot do the machining of the flywheel myself. I don't want to spent any money at this project as long i'm not sure it will succeed.
I have used 12mm steel as a adapter plate. It sounds a bit heavy, but it is not that bad. I prefer steel over aluminium because i have moer faith in treathed holes in steel instead of alu.
The input shaft of the transmission doesn't have a center axle. So that's a worry less. The inputshaft is cut a little shorter (just a few mm) but it might be not nescesarry. I shortend it because i first planned to do a 8mm adapterplate. With a 12mm adapterplate cutting might be not nescesarry.
The best thing about the toyota tranny is the starter motor. Most other transverse engine's have the startermotor alongside the engine. But the toyota
has the starter on top of the tranny. The sprocket of the toyota seems to match the 12A flywheel. The position of the starter needs to move a few mm outward and away from the engine.
I use the 12A pressureplate with a toyota clutch disk.
Old Mar 24, 2006 | 01:58 PM
Bart
Some more pics:
Other attemps to make the bearing block
I didn't like these solutions. Bad feeling.
And it should go it this
Old Mar 25, 2006 | 09:07 PM
RX744CSP's Avatar
That is a cool car!
On to your question: if you get into the water jacket when you drill, it's not the end of the world. On this side of the pond, the 4.0 Jeep 6 cylinder needs sealant on one head bolt because it goes into the water jacket, and the older 302 (5.0 l) Ford V8's needed the same thing on some the exhaust manifold bolts. There are other examples as well, those are just two of the most common ones.
If you drill and tap a hole in the iron and hit water, I suggest using a stud rather than a bolt, with something like Loctite on the threads to seal it.
Someone mentioned using the exhaust studs. I'd want to avoid this, as the exhaust studs go into aluminum and torquing them tight enough to keep the plate from moving could conceiveably pull the threads out of the housing, as that's not the job they were intended for.
You mention the Toyota transaxle has no 'center bearing', what I take to mean no 'pilot bearing' to center the input shaft in the flywheel. Out of curiosity: how are you centering the transmission to the eccentric shaft?
Old Mar 26, 2006 | 05:43 AM
Bart
I like that idea. But i prefer to drill not through the water jacket. If i drill through, i end up with splinters. But is good to know that it is not the end of the world.
Yes, i mean the pilotbearing.
The transmission is dismanteld. I had a shaft made as a center tool. The shaft comes in place of the input shaft. It has a pilot pin (is that the right word?)
Old Mar 27, 2006 | 11:01 AM
Wankelguy's Avatar
No, I mentioned welding a bolt to the exhaust FLANGE, which is steel.
Old Apr 17, 2006 | 01:10 PM
Bart
I just get my hands on a brand new front iron. It's a pity but it will be sacrified for sience. The metal outside is beefy enough to make treathed holes in.
Shortly i start making the final drawings for bearingmount, adapter plate, engine mounts, and other bits. these will be made on a waterjet cutter. I also making (a few) new header flanges. I noticed on the old headerflange that the surface is deepend around the gasket. Can i use a flat surface flange instead? And does these flanges have to be that beefy?
Old Apr 17, 2006 | 02:18 PM
edmcguirk's Avatar
I just came across this and even though it would be heavier, I think it would be a better solution.
http://www.rotaryaviation.com/engine_mounts.htm
http://www.rotaryaviation.com/RV8Project.htm
Old Apr 20, 2006 | 03:18 PM
RX744CSP's Avatar
The header flange has to be really thick, since there is such a long distance between the header mounting studs. Any thinner, and it would be prone to warpage (rotary exhaust is REALLY hot!).
That aviation mount is nicely designed, but I think it would be overkill for this project.
Old Apr 20, 2006 | 05:36 PM
KeloidJonesJr.'s Avatar
strictly business
Originally Posted by bart_heemskerk
Some more pics:
What are these?
Old Apr 21, 2006 | 01:39 PM
Bart
The mount for the drive shaft bearing is sorted. Making threated holes in the front iron is no problem.
The header flange which was on the 12A was 14 mm (0,55 inch) thick. I wonder if a 12 mm (0,47 inch) is too thin. I get the adapterplate and several brackets / mounts from a 12 mm steel sheet cut by waterjet. I can add the header flanges with no extra costs.
Originally Posted by eatmyclutch
What are these?
Old Jun 23, 2006 | 10:27 AM
edmcguirk's Avatar
Any new info on this project?
