(REFERENCE) The Upgrading a Stock Rx-7 Thread
Old Dec 16, 2007 | 02:09 AM
  #101
TeamSMS's Avatar
Originally Posted by redbstd
fiberglass/carbon fiber hood, fenders, hatch, doors. fab rear end, aluminum rad and shroud, fab control arms
Dont see anybody making or getting CF fenders or doors made....and there pretty much is no "hatch" to make cf...its just glass that opens up.
Old Dec 16, 2007 | 02:17 AM
  #102
redbstd's Avatar
Red 84 SE
well arnt you mister picky. oh and lakewood can make anything out of fiberglass. even a tampon for that bleeding mangina of yours. lol jk
Old Dec 16, 2007 | 02:36 AM
  #103
TeamSMS's Avatar
lol im just pointing out facts...
Old Jan 30, 2008 | 07:45 PM
  #104
Shortydestroyer's Avatar
Not to sure about K&N
Originally Posted by Metallic_rock
COLD AIR INTAKE Preferrably with a K&N intake.
High performance spark plug wires are a plus.
I know K&N filters are supposed to increase airflow but the problem is that K&N is a dry element with much more open element letting dirt get in, I'm not sure what an alternative would be but I know for diesels the is S&B which is apparently pretty god. I got this from my boss who worked at the calgary drag strip and an autoparts store for fifteen years, I'm trusting his judgement.
Also K&N are probably the way to go if you stay in the city and there isnt to much dirt and grime flying through your intake, my best guess
Old Jan 31, 2008 | 06:12 AM
  #105
Glazedham42's Avatar
Resurrecting Gus
K&N filters use an oil medium to trap and suspend dirt particles in the filter. They are not necessarily "dry".
Old Mar 22, 2008 | 10:33 AM
  #106
1985RX-7's Avatar
I have a friend with a 84 gsl-se and he bought the tunable ecu and loved it plus you can tune alot of power out of your car that you already had.
Old Mar 22, 2008 | 12:41 PM
  #107
TeamSMS's Avatar
where did he buy that?
Old Mar 22, 2008 | 07:27 PM
  #108
elwood's Avatar
I know K&N filters are supposed to increase airflow but the problem is that K&N is a dry element with much more open element letting dirt get in, I'm not sure what an alternative would be but I know for diesels the is S&B . . . Also K&N are probably the way to go if you stay in the city and there isnt to much dirt and grime flying through your intake . . .
As was already stated, K&N is an oiled filter, just like the S&Bs. I use an S&B, mostly because they're a lot cheaper than the better known K&Ns. As for the airflow, I'm curious if anybody has seen a performance gain. Although the K&N (or S&B, or whatever) may flow better than OEM, it won't make more power if it isn't the limiting factor in the system. Think of it this way -- you can strengthen a link in a chain, but if it wasn't the weakest link, the chain won't be any stronger.
I have a friend who is a calibrator for an OEM, and he found no gain on a popular SCCA racer when a K&N was swappen in -- or even if no air cleaner was used for that matter. Wasn't the weakest link . . .
BTW -- my car's a turbo FB, so I have no OEM baseline to compare to.
Old Mar 22, 2008 | 08:12 PM
  #109
orion84gsl's Avatar
My 7 is my girlfriend.
The more important aspect of a K&N filter is that they are reusable, so for $40 you have a filter for the life of the car, instead of a new one every 30K. If you change your regular filter as needed it should not flow that much worse than a brand new K&N.
Old Apr 11, 2008 | 02:08 PM
  #110
Stephen Raj's Avatar
Newbie
Question on mods to carb
Originally Posted by timmya2
sorry it was late at night and i was bored
ok i wanna contribute..
mods- put a 48 IDA weber in... or if u wanna use it as a daily driver... just modify the stock nikki carb.. to open the 4 butterlys together or faster..
this should be as good as the weber and wont use so much fuel...
Timmaya,
How do you go about modifing the stock to open the 4 butterflys together or faster??? you can email me direct if Ok with you.
Thanks
Steve Raj
steve_j_rajcula@raytheon.com
Old Apr 11, 2008 | 02:22 PM
  #111
Resurrecting Gus
Steve, do a search for "mechanical secondaries" or "mech secondaries". You'll get all the information you could ever want. Essentially you remove the vacuum operated diaphragm from the carburetor and wire the linkage for the primaries and secondaries together. The linkages are setup progressively so that the secondaries will begin to open when the primaries are at about 1/3 capacity. Both the primary and secondary butterflies should be fully open at the end, thus giving you true wide open throttle. You'll also want to look into Sterling's accelerator pump modification. Just do a search for "accelerator pump diaphragm" or "AP diaphragm". Once again, you'll find all you'll want to know.
Good luck and welcome,
Jamie
Old Apr 13, 2008 | 10:15 PM
  #112
illi11's Avatar
BAMF user
Originally Posted by ZachstylezRX7
Hey i want to know more about this... is there a writeup of some sort Jimmy? (btw i love your car)
Zachstylez
i would also like to know how you do this
Old Apr 13, 2008 | 10:25 PM
  #113
shm21284's Avatar
Fabrineer
Originally Posted by 84stock
Install a Camden
Whaaa??? T2 swap>Camden for many reasons: cost, power, torque curve in general. At least on a 13b. Unless you don't like swapping wiring harnesses. Personal experience tells me this.
Old Apr 22, 2008 | 09:51 PM
  #114
1stGenJake's Avatar
need hood
Originally Posted by Jeff20B
Loose the rear sway bar? This won't make it faster, but it'll help cornering (not sure if that's for '84-'85 cars only)
im pretty sure they had sway bars 83 to 85, but what do i know
also, take all that emissions bullhonkey off, and throw it in the garbage.
Old May 10, 2008 | 08:43 PM
  #115
blackdeath647's Avatar
weak minds wear the crown
Originally Posted by vizion47
im 16 and i bought this rx as my first car, my friend crashed it but not to bad, so i bought 5 way adjustable tokico's, with pro-series eibachs, and poly bushings for suspension ( i also had to replace a control arm and ended up getting adjustable ones and then didnt use them and got one stock...so if anyone wants to buy these let me know), for the engine i got a DEEP SUMP OIL PAN now i can hold like a liter and a half more than stock, and rb headers to a catco converter to a 2.5 inch mid-pipe AND THIS IS WHERE I F***** UP...DO NOT BUY A PACESETTER MONZA EXHAUST THEY DO NOT SOUND GOOD, N E WAYZ I CHOSE TO IGNORE THAT, i also got a better distributor rotor and cap, some ngk wires and ngk multifire plugs(these are awesome and affordable), the rest of my money went into a motherf***** transmission swap from auto to manual...but hey now i can fix and build anything, we are swapping out my rear axle for a gsl-se and my buddy at dyna-trac is going to rebuild it and re gear it so my car should be fun and fast n e wayz the only thing i listed that no one else did is that deep sump oil pan...
I would like to find out some more about these "multi-fire" plugs, i don't think i've ever heard of these, then again i'm relatively new to cars and stuff...anyways if there's a link, let me know, thanks.
Old May 10, 2008 | 09:02 PM
  #116
also, i would like to have a link of someone who would mod a nikki for me, i live in a small town where the way to fix rotary engine problems is to "drop a 350" in it. i hate it, so i need all the help i can get from other places, i only know of two people who can work on rotary engines here and never heard of being able to mod the nikki instead of doing a holley or webber swap. thanks.
Old May 11, 2008 | 11:09 PM
  #117
dangerousdarren's Avatar
Dangerous Darren
i know what you mean, when i got mine and was trying to get it running i got so tired of tards saying "put a small block in it". it's an rx-7, it is supposed to have a rotary motor. i like my wierd looking little wankle motor thank you, i will keep it (or at least some type of rotory, i saw a very interesting 1st gen with a turbo cosmo 2.0 taking a 350z's lunch money...lol)
Old May 12, 2008 | 05:47 AM
  #118
vipernicus42's Avatar
Rotoholic Moderookie
If you want a modded Nikki, the guy to talk to is the guy who started this thread : Sterling.
Due to vendor rules I would not be able to discuss specifics here but if you visit his website at www.sterlingmetalworks.com you'll be able to get some info and contact him.
As for the "multi-fire" plugs, I think he was talking about the stock NGK BR8EQ-14 and BR9EQ-14 plugs that have four spots for the spark to jump to. They don't actually fire multiple times (unless you install an MSD ignition box, but that's another topic altogether) they actually only fire once, but having the extra contact points means better chance of being able to spark on fouled plugs.
Jon
Old Oct 20, 2008 | 08:11 PM
  #119
good2go_rx7's Avatar
yo i have a some what stock 82 rx7. the only thing thats been done is the spark plug wires and exhaust. anyone that know of cheep-ish upgrades for me email me vipernic@juno.com 12a motor by the way. thanks
Old Oct 21, 2008 | 10:32 AM
  #120
Dangerous Darren
um, dude, did you even read the rest of this thread? there are several good ideas. also you might try that thing up at the top that says "search" that should give you all the upgrade ideas you could want.
Old Oct 21, 2008 | 11:08 AM
  #121
chepx7's Avatar
Eat,Sleep,Live Rotary
^^^ what dangerousdarren said ^^^
Old Jan 13, 2009 | 01:46 PM
  #122
my84gslrx's Avatar
just chillin
make sure secondaries are opening is right, mine werent opening when i had my brother sit on the strut tower of the car looking into the carb while i drove and put the motor under load.
Old Jan 13, 2009 | 01:51 PM
  #123
IanS's Avatar
Ricer
lol, thats safe
Old Jan 13, 2009 | 08:12 PM
  #124
my84gslrx's Avatar
just chillin
haha yea right, couldn't think of any other way, not enough vacuum at idle
Old Jan 13, 2009 | 08:59 PM
  #125
jd89's Avatar
street port baby thats all you need to know plus supporting mods of course
