Building Peripheral Port housings
Old Apr 26, 2008 | 03:17 PM
  #476
BLUE TII's Avatar
Rotary Motoring
The problem I see with the screen is it will actually preserve the bubbles in the frothed oil in the void of the screen.
You want a smooth flat sheet for the baffle so that the surface tension draws the oil in each bubble down to the sheet of oil film on the baffle plate as fast as possible so you have more liquid oil and less froth.
You can paint your porous cast oil return surfaces with Glyptal as well to serve the same purpose.
Old Apr 26, 2008 | 04:56 PM
  #477
ultimatejay's Avatar
What ID are the 12app drag racers using?
Old Dec 23, 2008 | 09:04 PM
  #478
CHB's Avatar
CHB
Newbie
DelSlow,
referred to the photo above, the front rotor is exactly at it's TDC? is the e-shaft's lobe at it's highest point pushing toward front rotor when it is on TDC?
i am having problem finding true TDC without gettting the engine dismantled
Old Nov 24, 2009 | 11:12 PM
  #479
puna rotary's Avatar
just wondering on the port timing and if you could give me some info on how you marked it out on the housing ?
any help would be much appreciated
Old Jan 13, 2010 | 01:43 PM
  #480
PINOYROADIE's Avatar
This is an awesome thread!!!
Old Jan 27, 2010 | 05:00 AM
  #481
Pedro Racing's Avatar
Originally Posted by Bridgeported
There is a huge debate over if it's necessary or not.
Most AUS/NZ rotary builders will swear upon it.
Most NA/PR rotary builders don't do it.
I'm not sure what that tells you though...
I know some rotary shops have given gurantees on their modified engines they sell to people that if they break from twisting they will replace it for free.
There doesn't seem to be a downside to dowling though (other than the price) so it could be good for a precautionary measure. Or is there a downside I just don't know about?
I've never dowelled a motor before... I've never made the power on a motor to require dowelling (yet)
"Most NA/PR rotary builders don't do it."
***how do you know... PR/we were doing it when we started building turbos back in 1982, most of you were not even born yet...
Old Jan 27, 2010 | 04:36 PM
  #482
nillahcaz's Avatar
you are missed
Umm... the post you are responding to is 7 years old.
Old Jan 27, 2010 | 08:05 PM
  #483
Chuck Norris FB's Avatar
Very useful info on this thread...Thanks
Old Jan 28, 2010 | 10:10 AM
  #484
just making sure things are said right for the record here!
Old Mar 10, 2010 | 06:46 AM
  #485
Rub20B's Avatar
Exhaust Manifold Leak
Bringing some new life into this nice topic..
I'm thinkering about making such engine in a year or so.. I have a good 4port rx8 engine, and because it has 10:1 CR and lighter rotors it will be quite good.. engine will get telescopic intake like mazda did for the 787b..
now I could use rx8 rotors in s5 TII engine, or I could use complete rx8 engine with TII rotor housings.. question is, what effect will it have when I both have pheripal and side exh ports?
engine will be for a circuit racing and power band from 6000-9500rpm; need 300hp at least
Old Mar 10, 2010 | 07:42 AM
  #486
Crispin38's Avatar
o.O
I dont think you're power band will start till about 7K or above, even with fuel injection. But it should definetly make more then 300hp.
Old Mar 10, 2010 | 08:24 AM
  #487
Rub20B's Avatar
If I look at the lemans engine they had quite good torque at 6000 rpm (around 300Nm for 2 rotor equivalent).. I will try to keep overlap as low as possible by making it almost D shaped port (flat side on the bottom offcourse), offcourse most of the torque lies in the resosnace tuning of the intake manifold, but it will be quite straightforward to control the trumpets by PWM signal with the microtech I'll use..
Unless the exh velocity will be too low to start comin in the powerband at reasonable rpm due the huge port area with both pheripal and side ports
Old Mar 10, 2010 | 05:12 PM
  #488
user 893453465346's Avatar
Red Pill Dealer
Search Rotary Aviation's website. The used to have a dyno graph of a Renisis engine with both peripheral and side exhaust ports. The torque was awesome!
Old Mar 11, 2010 | 03:05 AM
  #489
Wink
Here's the dyno sheet of the p-port renisis,although some people bitch about the H.P but keep in mind that the power band almost peaks a 7200rpm. which is great for reliability compared to a regular p-port engine that has to rev at close to 10,000rpm's for that same power band.
Old Mar 11, 2010 | 03:25 AM
  #490
Rub20B's Avatar
is this with only side exh ports or both side and P-exh ports?
Old Mar 11, 2010 | 12:15 PM
  #491
Rub20B's Avatar
might make close to 300hp with a shorter intake at higher rpm.. advantage is that yoo can have diff lengths for the runners for side and peripheral exh boards to widen de powerband a bit more
Probaly just end up using the renesis rotors in the S5 engine..
I also looked on rotary aviation but couldn't find the dyno mentioned :/
Old Mar 11, 2010 | 04:55 PM
  #492
nillahcaz's Avatar
you are missed
I'm having trouble reading what you said but if i understand you, If you add peripheral exhaust it will no longer have the low overlap that makes it have a low redline. If you are not talking about adding PPort exhaust, the exhaust runners are so shitty that changing exhaust tuning has almost no change in power.
A variable runner intake will help but most people are to lazy, to obsessed with peak HP or to obsessed with weight to make one.
Side ports only
Old Mar 11, 2010 | 08:54 PM
  #493
Side ports only
Thank you for answering it for me Not sober enough for me to answer
I agree that with this kind of setup,a variable intake runner efi intake would increase the power band by 20 to 40 hp?? more than whats on this dyno chart.
But the side exhaust port could use a little work,ie ported for a smooth transition or port it for an early opening.there is about 1 inch of port material that that can be ported downward for an early opening, you do that plus the intake that you have just described,should yield you about same h.p as regular p-port but more reliably..
Old Sep 17, 2010 | 11:31 PM
  #494
drag 7's Avatar
i thought the manifold control the peak power
Old Sep 17, 2010 | 11:40 PM
  #495
drag 7's Avatar
what was the weight of the rx3 with driver just curious i have a first gen drag car pport g-force trans and chevy 12bolt rear end best time 10.48 at 126mph and it has carb on it trying to get the car in the nine second zone i am in ca name eric darby second fastest all motor rotary in ca
Old Sep 22, 2010 | 12:52 AM
  #496
biancaschule's Avatar
Wow, this thread is cool because you can learn many things by reading the post and you get some tips that might help us in our daily activity.
Old Jan 31, 2011 | 11:58 PM
  #497
fossil413's Avatar
where did you find out where to put the hole did you have a template or a spec you could give me or tell me where to get the template thanks
Old Apr 21, 2014 | 06:44 PM
  #498
doghouse's Avatar
Subscribed
Old Aug 11, 2015 | 12:48 PM
  #499
Medevack1's Avatar
Excellent work!!!!!!
Old Nov 15, 2015 | 12:08 AM
  #500
mannykiller's Avatar
Garage Hero
Revive to keep the P-Port Alive!!
hotshot2014
Jul 18, 2017 02:30 PM
Skeese
65
Mar 28, 2017 03:30 PM
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
Clubuser
11
Aug 31, 2015 12:25 PM
