this is what i traded my xbox for.
just fit a test pipe, I'm sure there's a local exhaust shop that will remove your old cat and put in straight pipe in it's place, just make sure you get the cat so YOU can take it o a scrap yard.
Why would you hollow out the cat? If it wasn't clogged I don't see the point... And usually the "belt fan" does a better job cooling than an efan does. The only time to really throw in an e fan is when your running an aftermarket rad.
man thats a score of a deal
best i ever got was a 1995 sunfire for 40 bucks the headgasket had a small tear in it causing a leak but new head gasket fixed that...im serious jealous of the deal you got this was for a 360 right because man if that was for the orginal one id be even more jealous
