Go Back   RX7Club.com > New Member Section > New Member RX-7 Technical
Old 11-04-09, 01:33 AM   #26
Drift_tune
Cause they can't drift? Well that's not true I could have did the conversion to my 450awhp talon but it costs more than the total cost of thecar and mods
Drift_tune is offline   Reply With Quote
Old 11-04-09, 01:35 AM   #27
Drift_tune
And I never bought it I traded a geo for it haha
Old 11-04-09, 11:55 AM   #28
Aaron Cake
Engine, Not Motor
Aaron Cake's Avatar
Send a message via ICQ to Aaron Cake Send a message via Yahoo to Aaron Cake
Originally Posted by trippdog99 View Post
if you have a turbo, can't you do a home made boost controller for pretty cheap and dial up the boost? Or save the trouble and buy a manual boost controller?
Yep. But the boost can only go up to 8 PSI before you need to upgrade fuel and install an FCD.
Originally Posted by Drift_tune View Post
Ok I get all this now haha , the question I have wanted to know is how hard is it to na/t the car? I have a shit load of good used turbos they are small and stock dsm turbos so like 15 psi tops but war all will I need and how much is a t2 turbo ?
See the FAQ. I'd suggest you do a TII swap instead. If you must turbocharge the NA, almost any turbo from any OEM car is going to be too small.
Originally Posted by fc3si View Post
i hollowed out my cat and the throttle response is a little better.
Make sure your aux ports are still opening.
Aaron Cake is offline   Reply With Quote
Old 11-04-09, 08:37 PM   #29
BlackfiresStyle
New Member
wow thought it could go higher than 8psi w/o upgrades...
BlackfiresStyle is offline   Reply With Quote
Old 11-05-09, 02:39 AM   #30
Drift_tune
I will probally just drop a tll engine into it
Old 11-05-09, 05:30 AM   #31
w.sen
w.sen's Avatar
Arron cake how many pound was you N/A -T set up running? And did you ever dyno it??
!!!! WANT TO BUY !!!
2ND GEN DOUBLE BELT ALTERNATOR PULLEY!!!
PM ME WITH INFO!!
w.sen is online now   Reply With Quote
Old 11-08-09, 12:50 AM   #32
bmeyer
dude you cant do shit for cheap on rx-7's when an OEM oil pressure sender is 79.00... good luck drifting...the tires cost will be enough to scare you alone! not really such a thing as "free mods"
bmeyer is offline   Reply With Quote
Old 11-08-09, 10:50 AM   #33
Aaron Cake
Engine, Not Motor
Aaron Cake's Avatar
At 13 PSI it put down 392 RWHP on a conservative tune, around 420 a bit later on a better tune. Turned the boost up to 16 PSI just a few months ago but have not been back to the dyno. Somewhere around 500 RWHP.
Old 11-08-09, 03:58 PM   #34
w.sen
w.sen's Avatar
thats amazing!! i have read you almost complete guide to turbo NA .and a couple differant things on your site. keep the good work
PM ME WITH INFO!!
Old 11-08-09, 05:49 PM   #35
fc3si
Rotorite
fc3si's Avatar
not true, just don't buy ridiculous wheels, i have 2 spare 15's i throw on the back to drift and when they blow out i go to the mexican tire shop down the road and get 2 used tires mounted for 30$
myspace.com/yamnaes
fc3si is offline   Reply With Quote
Old 11-09-09, 12:04 PM   #36
bmeyer
yeah i was thinking more along other lines yer kinda right there
