Rtek been wondering this for a while now?
Old Mar 18, 2008 | 10:15 PM
RotoriousRx7
so when datalogging and you are watching the index's of rpm h and l and the the t index and all that ....
my question is what does the 1 2 3 4 mean ? i have a small lean spot between 2k-2800 at light throttle but 4th and 5th gear only like say 40mph in 5th gear if you give x amount of gas it will go lean to about 15.5ish? so i have narrowed it down and changed the fuel % in all vacuum point at 2k and 2500 but still no fix? ill try and load a log.
dont understamd why my wbo2 is showing as analog not afrs?
Old Mar 18, 2008 | 11:50 PM
turbo2ltr's Avatar
From the manual:
Table Indexes
The two table index parameters allow you to log the X and Y index into the respective map. This is
useful to easily see where to make changes in a table. If the Fuel Table index is checked, you will see
two additional parameters being logged, one for the RPM index and one for the boost index. These
number relate directly to the rows and columns of the fuel table.
The Timing table index, when selected, will log either two or three parameters depending on the ECU:
The load index of the timing table, and one or two RPM indexes. On the N332 ECU, the T-Indx RPM L
relates to the 13 cells from 0 to 4096 RPM. Values will be 0 to 12. The T-Indx RPM H relates to the 7
cells above 4096. Values will be 0 to 6. All other ECUs only have one T-Index RPM parameter
representing the full range of the timing table columns.
Did you set up the WB02 scaling in the viewer?
Old Mar 19, 2008 | 12:02 AM
RotoriousRx7
yes its setup but sometimes i have to check it sometimes and just set it up again sometimes
thanks
Old Mar 21, 2008 | 11:16 AM
The Wankler's Avatar
FKITALL
I as well have a funny lean spot around 2500-2800.
Old Mar 21, 2008 | 02:26 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
me too, i have an extra 10% added in that area so that it doesnt stumble. but when it doesnt stumble it is too rich
Old Mar 22, 2008 | 12:13 AM
RotoriousRx7
alright then im not a dumb *** then...
but i never use the table version of the fuel map i just use the bar graph
Old Mar 22, 2008 | 12:53 AM
rogrx7's Avatar
Turbovert done.
1 volts?
2 volts?
3 volts?
4 volts?
I think u have to go into ATP and do the multiplier junk
Old Mar 23, 2008 | 11:07 PM
RotoriousRx7
ummm i have the aem uego.... its a preset...
Old Mar 24, 2008 | 12:08 AM
rogrx7's Avatar
Turbovert done.
What does the Uego have do with what the Rtek reads
Old Mar 24, 2008 | 01:07 AM
RotoriousRx7
when you set it to the preset for the aem uego u dont have to put in the multiplier info.. it does it for you....so you go to input and click the box for atp and then set it up by picking the aem in the preset list???
Old Mar 24, 2008 | 12:28 PM
FKITALL
You only get this hesitation while lightly revvvvving from 2500-3000k?
Old Mar 26, 2008 | 02:24 PM
RotoriousRx7
well i found it betwwen the 4/3 and 4/4
4 fuel /3 boost
4 fuel/ 4 boost
that is how that table goes right?
b 4
o 3
o 2
s 1
t 0
0 1 2 3 4
f u e l
but i know that the negatives are there but just trying to make sure thats ho its laid out?
ArmAnirx7
West RX-7 Forum
35
Mar 8, 2021 12:54 AM
sukimoto
Rotary Car Performance
Oct 26, 2015 02:37 PM
TeamRuffRacing
Adaptronic Engine Mgmt - AUS
Sep 30, 2015 08:13 PM
