forms of making a stiffer chassis
Old Nov 30, 2003 | 02:33 AM
rxspeed87's Avatar
just curious what can be done to making for a stiffer chassis
already know roll cage
and front/rear strut tower brace
but what else is there?
isn't there some sort of tie for the lower arms on the front of the susp as well?
also aware that for mustangs and camaro/firebirds they make sub-frame connectors could a set be made for the rx7 and would it make much difference?
and with the front/rear strut tower brace how much of a difference do they really make?
Old Nov 30, 2003 | 03:00 AM
j200pruf's Avatar
RIP Icemark
I know that Cusco makes a lower arm bar, and so does Mazdaspeed does as well.
As far as subframe connectors, I am not sure. I know about these from Corksport.
And something else that is helpful for chassis stiffening, is seam welding.
Old Nov 30, 2003 | 03:25 AM
rxspeed87's Avatar
what would I seam weld?
Old Nov 30, 2003 | 10:01 AM
everything
Old Nov 30, 2003 | 10:05 AM
rob20rx7's Avatar
Injected with a Poison
those crossmembers r pretty cool. who makes them?
Old Nov 30, 2003 | 10:11 AM
auto exe
Old Nov 30, 2003 | 11:28 AM
Center of The Universe's Avatar
You could strip out the the whole car, fill the cars frame with polyurithane. That will stiffin it up about.... 45%!
or add a rollbar for about 15%
The front and rear Strut tower bars make a very large difference, enough to notice.
Old Nov 30, 2003 | 11:29 AM
Seam welding is awsome too.
Old Nov 30, 2003 | 11:35 AM
silverrotor's Avatar
After Springs and Struts, Energy Suspension Polyurethane Bushings will tighten It up. Awhile at It, replace the DTTS stock Bushings. They are probably erroded as any 15 yr old+ car can be. Now you are talking firm.
Old Nov 30, 2003 | 04:27 PM
rxspeed87's Avatar
whats with this seam welding thing?
Old Nov 30, 2003 | 05:56 PM
all the seams on your cars chassis have some amount of flex to them, if you seam weld them (a spot every inch or so) it makes them flex less
Old Nov 30, 2003 | 06:17 PM
Turblown's Avatar
Turn up the boost
Turn the rear diff mounts upside down so the rubber faces down. Solid rear diff mounts
Rotary Performance Parts
Old Nov 30, 2003 | 07:52 PM
rxspeed87's Avatar
where are the weak spots in the FC chassis?
Old Nov 30, 2003 | 11:11 PM
sub9lulu's Avatar
does it make the car ... 45% heavier too ?
Old Nov 30, 2003 | 11:24 PM
mazdaspeed7's Avatar
mad scientist
Old Dec 1, 2003 | 08:04 AM
Bukwild's Avatar
no the foam does not make the car heavier. My dad's had 2 Ferrari's. 348 targa without the foam in the frame and the 355f1 with the foam in the frame and it had zero body roll in the corners and handled like a dream. this summer I am looking into getting this done to my vert.
Old Dec 1, 2003 | 08:52 AM
there are no certain spots that I can think of. its the chassis as a whole.
Old Dec 1, 2003 | 10:22 AM
No. I does add about 100 or so pounds, but what you get back from the fill is a rocksolid car. Moto on www.club4ag.com did it to his car.
Old Dec 1, 2003 | 10:31 AM
Icemark's Avatar
Foam fill the frame:
http://www.itwfoamseal.com/auto_aftermarket.htm
Old Dec 1, 2003 | 05:40 PM
Kim's Avatar
Kim
OBEY YOUR MAZDA
Originally posted by j200pruf And something else that is helpful for chassis stiffening, is seam welding.
Isnt seam welding the same as a full seam weld.
I dont think you want your car to limb around on three "legs"
Im sure spot welding is the word
Old Dec 1, 2003 | 07:22 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
put in a cage
Old Dec 5, 2003 | 12:53 AM
rxspeed87's Avatar
ok if I was to try to make a set of sub frame connectors where would I try to put the mounting points?
Old Dec 5, 2003 | 01:19 AM
I wish I was driving!
Subfrome connectors for mustangs run the entire length of the floorpan. Our subframe already does that, so its not necessary.
The foam makes a HUGE difference to the car.
Old Dec 5, 2003 | 01:24 AM
neofreak's Avatar
accept no imitations™
have you actually done it? or just repeating what everyone else has said?
if so, how difficult/how much to have it done?
Old Dec 5, 2003 | 01:28 AM
Of course I have done it. I am the type to buy the 10 at once so that I can do it to others, and can't afford to miss out on a deal .
It wasn;t that hard. Remove sill plates, drill some slightly larger holes, mix foam, pour in, make sure car is on ground (wheels touching), wait to cure, then cut off excess.
That is the basic install, I installed it in a couple extra places
