Where can i get bigger f/disc for my FC?
Old Jul 20, 2007 | 10:32 AM
FS_WTB's Avatar
looking for just the disc, between 12" to 14"
any one know where? or can i modify from some other cars!
Old Jul 20, 2007 | 12:44 PM
phoenix7's Avatar
300ZX TT brakes
BMW rotors (redrilled to fit)
endless brake upgrade
have you done ANY research?
When you upgrade to larger rotors you are sacrificing handling for stopping power. You are adding weight (rotational mass) to your car! Unless you're making 400+HP you're wasting time, money and the handling of your car. Please go research before you add/remove/replace anything in your car.
Old Jul 20, 2007 | 03:06 PM
FS_WTB's Avatar
thx for the advice
btw, which yr of 300ZX TT brake disc?
Originally Posted by phoenix7
300ZX TT brakes
Old Jul 20, 2007 | 03:24 PM
phoenix7's Avatar
well it's the same as if you're doing the swap for the 240SX any 90+ ZX will do. Search the forum for those that have done the swaps or try www.teamfc3s.org/forum
Old Jul 20, 2007 | 06:14 PM
Black91n/a's Avatar
Seriously, WHY? Are you getting fade at the track and have tried better pads, better fluid and ducting? If so then sure, you need it, if not don't bother, it's $2k that's uselessly spent upgrading something that's already more than capable of doing what you want it to.
Better brakes don't make the car stop faster, better tires do.
Old Jul 20, 2007 | 06:22 PM
phoenix7's Avatar
look into getting the 4 piston brakes that came on the GXL, S4 GTU, S5GTUs, TII if you want better contact but like I said earlier unless you're pushing 400+HP you're wasting time and money. If your braking system is not good enough then look into better/wider tires.
Old Jul 20, 2007 | 08:02 PM
MidnightOwl's Avatar
2 Rotors, 1 Turbo
I think he may be looking for the big brake look. I believe someone makes an adapter to run larger brakes, and Brembo makes a kit, I believe.
Old Jul 20, 2007 | 08:11 PM
Sideways7's Avatar
From a performance standpoint there is NO advantage to running larger brakes. With proper supporting mods, the stock size (for turbos, GXL, etc) is more than sufficient for even severe track conditions.
ls1swap
17
Jun 3, 2024 03:25 PM
Rotate86
May 18, 2018 02:44 PM
Turblown
Sep 30, 2015 05:58 PM
pfsantos
Sep 30, 2015 01:29 PM
