Rtek Flood Clear Components
Old Nov 29, 2006 | 02:12 PM
FCKing1995's Avatar
Rotary Slave
Does anyone know what components send a signal to the ECU for the flood clear? My 1.8 isnt letting me use the flood clear thing. I adjusted the tps thinking maybe it wasnt acting right and still nothing. So what else can I check to maybe figure this out. thanks in advance
Old Nov 29, 2006 | 10:43 PM
winter39's Avatar
Got Rotors?
I had to change my TPS even though it was adjusted properly. From what I have read the TPS can be dead in certain spots (eg: when you sweep through the tps readings slowly you find a dead spot). I pushed my plunger in / out several times and noticed that in a couple of places (WOT) it would zero out. I then swapped my TPS and now flood clear works. This may be your problem too. Anway, here is a thread that I wrote not that there is any more information here for you.
https://www.rx7club.com/rtek-forum-168/1-7-flood-clear-issue-573416/
Good luck
Old Nov 30, 2006 | 12:51 AM
turbo2ltr's Avatar
Did you adjust it for 1 volt at closed throttle?
How many volts does it read at WOT?
Turblown
Vendor Classifieds
12
Oct 17, 2020 03:25 PM
Turblown
Sep 30, 2015 05:58 PM
SSpyderX
1st Gen General Discussion
Sep 29, 2015 04:37 PM
