Rtek How much boost???
Old May 16, 2008 | 05:11 PM
Fc3s_d1jp's Avatar
How much boost???
Just wondering how much boost my setup can handle on rtek 1.8? Its an s4 stock turbo?
Old May 16, 2008 | 05:34 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
the rtek ecu can sense up to 1 bar (14.7psi), but in your case teh limiting factor is your stock turbo.. i wouldnt run more than 10psi if you dont want to blow out its oil seals
Old May 16, 2008 | 05:40 PM
Fc3s_d1jp's Avatar
Thanks, Just wondering because I have really bad boost creep, so I ported the wastegate to were the flapper is barely covering the hole. But today I was driving it seeing if it would hold boost, and I took it all the way to 14psi without realizing. Just worried I might have hurt the motor. I guess I will have to port it some more and weld a different flapper.
Old Jun 10, 2008 | 01:22 AM
JCurry's Avatar
Shpee
prob didnt hurt the motor seeing as the stock turbos dont move alot of air.....
Shainiac
Jul 17, 2019 02:20 PM
Jeff20B
73
Sep 16, 2018 07:16 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
