Stock weight and weight reduction
Old Dec 25, 2007 | 01:47 AM
shwine617's Avatar
I saw on the sales brochures that 2 gens weigh around 2625-2700 lbs.
just wondering if someone actually weighed their stock car and got a similar weight. also what type of significant weight reductions can be done and what type of weight is atainable.
I am asking because my current mazda is about 2200(fully gutted), and I want to swap the motor from it into a 2nd gen rx7 and was wondering if i get it close to the same weight.
thanks
Old Dec 25, 2007 | 09:25 AM
arghx's Avatar
rotorhead
i think there is a thread in the archive about the weights of specific parts
Old Dec 25, 2007 | 09:34 AM
Icemark's Avatar
Stock weights of parts is found in the FAQ for FC sticky thread found at the top of this section.
stock weight of cars is found in standard and options sticky thread found at the top of this section.
Old Dec 25, 2007 | 11:09 AM
RETed's Avatar
We've managed to get a stock 1990 Turbo II to weigh down to 25xx without any drastic (i.e. cutting) weight reduction at full race trim.
-Ted
Old Dec 25, 2007 | 11:37 AM
SpeedOfLife's Avatar
rotors excite me
IIRC, the S5's are also a little fatter than the S4's
Old Dec 25, 2007 | 12:13 PM
blmcquig's Avatar
everything will be okay
I had my S4 sport swapped TII weighed, and came in at 2900 even, with Myself, a FULL tank of gas, and all the tools, books, junk, and spare that i usually carry in the car, after carefully weighing each item, the total was 335 in extras. so figure, 2900 - 335 = 2565 for just the car, with no fuel or tools/spare tire/me/ etc.
Old Dec 25, 2007 | 04:34 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
my 88 TII with no weight reduction weighed 2800 lbs even
Old Dec 25, 2007 | 05:42 PM
86GXL's Avatar
Rotary ≥* Soul
86 Sport w/sunroof
1/4 tank
Power steering
Full interior
No sound deadening
No A/C
aluminum hood
Single exhaust
No spare tire/jack
No emissions
Maybe a few other minor things i cant remember
Weighed in at 2445lbs without driver.
Old Dec 25, 2007 | 06:10 PM
GreatShamanGT's Avatar
Roxann7
Really? Is this really true?
Old Dec 25, 2007 | 06:21 PM
rotary roderick's Avatar
Rotor7ven
^^^ yeah
s4- 146hp
s5- 160hp
Old Dec 25, 2007 | 06:36 PM
rotors excite me
YES, read the FAQ and specs threads as suggested (because that goes for anyone wanting to know about the RX-7). And just so no one is confused... I said FATTER, not FASTER, and since the S5's were FATTER, the FASTER bit when they're in stock form has been beaten to death and I don't even care to get into that argument. This is a quick look at what the specs thread has to say about curb weight:
1991 curb weight:
coupe: 2787lbs
turbo: 2987lbs
vert: 3071
1988 about 50 less than the above /\/\/\ for all models
1987.5 a little heavier than immediately below \/\/\/
1987 curb weight:
coupe: 2700lbs
auto: 2735lbs
turbo: 2850lbs
1986 curb weight:
manual: 2625lbs
auto: 2695lbs
R3N5LOW's Avatar
same as mine 2800 dead even and its a 88t2
Old Dec 25, 2007 | 11:47 PM
shwine617's Avatar
thanks, i read the stickies and did a search. I just wanted to know the actually weight of peoples cars that were responding. So a gutted race car could probably weigh around 2300-2400lbs with no lexan and minimal fiberglass. If this is true, that would be pretty good for me, I would be sacrificing about 200lbs. But be gaining a RWD car with a lot beefier of a drivetrain.
this is my current vehicle and the swap plans are here if anyone is intrested.
https://www.rx7club.com/other-engine-conversions-non-v-8-118/fe3-piston-engine-into-rx7-714967/
I appreciated the responses
Cory
Old Dec 25, 2007 | 11:55 PM
phoenix7's Avatar
go with an 86 base to start off with the lightest model. This is for the FE engine swap right?
Old Dec 26, 2007 | 08:44 AM
gxl90rx7's Avatar
nice! it was a good year LOL
Old Dec 26, 2007 | 01:07 PM
shwine617's Avatar
yes its for the fe3 swap, I am going to go look at an 86 this week.
Old Dec 26, 2007 | 01:22 PM
dean23's Avatar
pwned
ive been wondering about some of these weights too. ive got an 88 body with a 90 engine in it and then a big IC in the front. i did a quick spreadsheet on weight vs power. here's what i came up with.
QM TIME Power VS. Weight
8 0.3860
9 0.2710
10 0.1977
11 0.1487
12 0.1143
13 0.0900
14 0.0720
it reads that if you want to run a 14 second pass, your going to need .07 HP per pound ( including driver) and so on. ive personally always wanted a 10 sec car so i have a few options. either gut my car and keep my hp a little lower, or go for more power. im going to do both
Old Dec 26, 2007 | 01:42 PM
Roen's Avatar
The Silent but Deadly Mod
What's an FE?
Do you mean SE aka SE3P, i.e. the RX-8 with the 13B-MSP engine?
Old Dec 26, 2007 | 03:25 PM
blmcquig's Avatar
yeah, an FE, as in, an RX8. called either FE or SE depending on who you are.
Old Dec 26, 2007 | 04:41 PM
pistones's Avatar
wow, why is everyone's cars coming in so heavy? i weighed at the track, full interior half tank of gas some tools and myself came in at 2748 lbs. i only weigh 170 lbs.
Old Dec 26, 2007 | 05:13 PM
ericgrau's Avatar
Clean.
I believe there are people around here with cars weighing from 1900-2200 lbs. fully gutted and perhaps with some cuts (I don't remember). But 2200 seems to be the common level of crazy while 1900 is the extreme level of crazy, so hopefully it doesn't take too much to reach 2200. If I remember right you can gut 200lbs. out of the interior just from upholstery, passenger seat, etc. The base model weighs 2626 lbs. So that puts you at 2426lbs. right there.
Old Dec 26, 2007 | 09:24 PM
shwine617's Avatar
I think you are confused about the fe engine I am refering to.
The one I am using is an FE3. Its a JDM mazda 2.0 DOHC piston engine. I have one in my mx6 and want to go rwd.
Old Dec 26, 2007 | 10:23 PM
Roen's Avatar
Ah.....that makes more sense. I was wondering where FE came from when referring to the RX-8, it's not like it's anywhere in its VIN or chassis designation or that the RX-8 is a successor to the RX-7 in any way, shape or form, besides the rotary engine and the first two letters and symbol of the name.
Old Dec 27, 2007 | 01:34 PM
blmcquig's Avatar
ah, yeah, that does make more sense. guess i dont really think about piston engines that much.
Old Dec 27, 2007 | 04:24 PM
stylEmon's Avatar
FC since 99
Mine is a 87 T2. Got it to the 2520 range with no cutting as well. I did take the dash out, and remove a lot of little boxes and bolts before I put the new dash in.
Took out the, spare tire, rear washer tank, all emissions, air pump, power lighter exhaust system, lighter rims,...
Still have AC tho.
