What is this?
Old Aug 26, 2007 | 03:04 PM
Turbo II Rotor's Avatar
Who Shot the Sheriff?
What is this?
I'm in the process of swaping in a new transmission. This was bolted to the slave cylinder and was plugged into the harness. I didn't see it and the wire pulled out. What is it and what does it do?
Old Aug 26, 2007 | 03:09 PM
The numbers are 0.47/250
r17g
Old Aug 26, 2007 | 03:25 PM
87 t-66's Avatar
not a drifter
it usually gets grounded to the tranny i believe, im not sure what its for though
Old Aug 26, 2007 | 03:27 PM
djmtsu's Avatar
DGRRX
I thought it did something to help the thing that its attached to do its job correctly. Maybe I'm wrong though.
Sorry I couldn't help.
Although, on mine, its bolted though one of the bellhousing bolts, not the slave cylinder.
Old Aug 26, 2007 | 03:39 PM
TweakGames's Avatar
FD pro licensed driver
it is a oil pressure signal regulator if I remember correctly ... I dont use mine but I have also blew 3 stock oil pressure gauges.... :P
Old Aug 26, 2007 | 03:56 PM
Sideways7's Avatar
It is a capacitor for the oil pressure gauge. It evens out the signal going to the gauge and prevents the gauge from being harmed if the sensor or wiring goes bad.
Old Aug 26, 2007 | 04:01 PM
AeRx7Dallas's Avatar
Sideways 7 has it right
LOL found mine dangling behind the starter lol! Yeah, Capacitor for oil gauge. grounds to motor
djmtsu's Avatar
DGRRX
Lol, so maybe that was my problem.
We accidently dented my sending unit when we put the motor in. Gauge pegged out until it broke internally. When I was installing my Autometer sending unit, I noticed that we forgot to ground the capacitor (it was just hanging there but the starter).
Whoops!!
Old Aug 26, 2007 | 06:30 PM
Ok thanks for the help. The wire broke flush with the capasitor so I soldered a peice of solid wire to it and the plug to the solid wire. I hope it works otherwise i'll be taking a trip to mazad tomorrow.
Old Aug 27, 2007 | 02:09 AM
rx7-kid's Avatar
Incomplete Project
Did it work the soldering. i broke mine too so i solder mine together. but i cant get my car to start yet. so i dont know.
