Need Guidance on Breaking in a new Engine
As the title states: I need some guidance on breaking in my new motor...
(I'm sure they're stupid questions for most)
How many miles do i need to break it in for? Where should i keep the rpm's? How low should i keep the boost? etc..
When I bought my fd the previous owner told me to premix 4oz of 100% sythetic 2stroke oil w/ the gas. I always did so. I know that's the topic of much debate, my question isn't wether or not to do so, (because i plan on it) but should i do it on the fresh motor, or wait until it's broken in? Also, what about the use of synthetic vs mineral oil?
Any help is greatly appreciated.
Thanks,
Brent
Thanks,
Brent
Thanks,
Brent
Thanks,
Brent
What are your mods?
synthetic vs mineral oil has been discussed you can use the search function for that but mazda says only to use mineral oil but many people have different opinions.
Whatever, a lot of the "break-in" procedures are based on anecdotal evidence. Talk to the guy who built your engine. I hear that Kevin of Rotary Resurrection has a good rep for rotary engines, so check out his procedures: CLICK
Check items 10 & 11.
Engine was built with brand new housings & streetported, RA Super seals w/ race springs, atkins master kit (minus the seals & springs...), & new twins.
I have an ARC induction w/ K&N filter, hks ssqv, 3" turbo back exhaust, air pump pulley delete kit, aluminum ast, koyo rad, and probably a few things i'm forgetting.
To Clarify About the Synthetic vs Mineral Question:
My question wasn't which one to use during regular driving, (I plan on using the sythetic), but which to use while breaking in. I've heard that mineral oil expediates break in time. Basically just asking about the validity of that statement.
I have searched the topic somewhat extensively. However, as I'm sure you are all aware of, one must wade through countless pages of this topic to get a fraction of the answer desired. I appreciate any and all help/input/feedback. Thanks Guys.
~Brent
Yep, there is much debate on the oil issue. I also run Castrol GTX 20w-50 in the motor and use Klotz 2 stroke syn. as premix.
Also, I didn't see you mention it but are you still runing the oil metering pump. When I bought my FD from the previous owner, he neglected to tell me the OMP was removed and I would therefore HAVE to run premix. I ran thru two tanks of gas before I realized that (which might explain my blown Apex seal).
that's a pretty heavy oil. what weight do you regularly use?
thank you!
thank you!
https://www.rx7club.com/forum/showth...ghlight=protek
Im in the same boat as you, im breaking in my new engine, people have told me 1000 - 2000 miles with no boost
break it in on the dyno? I thought you cant dyno until engine is broke in? because i need mu car dyno tuned
i meen u can ask around n get recommendations...its hard to get any hard facts on the matter, its more of a preference thing... ive seen people recommend 1000-2000miles with no boost.... ive also seen people rebuild there motors let it idle for a while, go for a drive, come back change the oil and hop on the dyno
i had someone tell me to take it super easy, no boost, for 1k miles then change the oil, and then red line every gear. i dunno....
Also, motor will be streetported, it has an arc intake , and 3inch turbo-back exhaust (no cat...), air pump pulley delete kt.... i have the stocker ecu still in; am i in danger of running too lean and possibly blowing the motor again?
You really shouldn't do this! Get yourself a Power FC and get your car properly tuned to benefit from your mods and most importantly to prevent a repeat engine failure. You're asking for trouble if you run your stock ECU with what you've just described.
A couple of random points and questions:
were new rotor and stat gear bearings installed during your build?
run 20w50 oil year round out there at the NTC, mineral oil for breakin and synth therafter. Edit: I spent two rotations out there in the winter and know it can get *****-cold, so when temps drop down below the 50s I tend to switch to 10w30 synth. www.rx7.com sells Idemitsu oil, which is the only product I use.
You'll want around 1.5 oz's premix for every gallon of gas.
There's nothing wrong with a little boost on breakin, how do you think shops verify the proper function of the stock seq twins before a car with a new engine leaves?
Get a power fc yesterday, and I hope your wastegate is ported, or boost creep might make your life miserable.
just barely used rotors were installed (couldn't afford brand new), e-shaft replaced, all bearings replaced, and exhaust intake and wastegate were ported. if you use synthetic oil, won't the omp need to be removed? at least my understanding was synth oil could not be used w/ omp. <--- my mechanic recommends the installation of an omp on the new motor. <--what do you guys think? *i'm saving my pennies for a power fc.
