Rtek Rtek2.0 PocketLOGGER software Survey (for owners)
Old Nov 29, 2006 | 08:24 PM
turbo2ltr's Avatar
When viewing fuel or timing maps, what view do you use the most? (Table/Bargraph/3d Graph)
Please comment on the usefulness of each view...why you like one over the other, is there one you never use, etc.
Any comments on user interface improvements or feature requests are welcome.
The Rtek PocketLOGGER software has been undergoing a pretty major rewrite. Mostly for support of the other ECUs, but also UI and speed improvements. So if you have suggestions for the software itself, now is the time to make them.
Old Dec 7, 2006 | 09:42 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
I use the bargraph the most for fuel adjustments, havent really played with timing yet.
One problem i have noticed when datalogging is the pda will briefly display "lost connection" or similar (i forget the actual message), and the log is stopped. It may be something with my cable or setup, as it only happens on wot runs?
Possible improvements/features:
-Importable/exportable fuel and timing maps (excel format?)
-I know there are discussions about the timing/load indexes, but it is difficult to tune to a load index instead of rpm or boost index. I suppose a fix to this is already in the works?
-When you are viewing the logs on the pda, there is no marker to move across the graph to get specific values, like on the plviewer. When tuning, i have to transfer the logs from pda to PC to be able to see the values at specific rpms, which is cumbersome
Old Dec 7, 2006 | 09:56 AM
turbo2ltr's Avatar
Thanks for the input.
Just run your stylus across the graph. The values at that point are all updated as you move it.
What Palm are you using?
Old Dec 7, 2006 | 10:25 AM
gxl90rx7's Avatar
ok i probably just missed that, ill take a look at it today
Im using the palm m100, i think the problem is with my cable, it probably gets dislodged with the vibration or something, i just wondered if anyone else gets that problem
Old Dec 12, 2006 | 09:23 PM
edomund's Avatar
Bastardized RE AE
I get the same problem not sure if it the connection or the software though.
Old Dec 22, 2006 | 05:50 PM
JWteknix's Avatar
i also get the lost conection problem
Old Jan 7, 2007 | 11:41 AM
gxl90rx7's Avatar
as far as new features, can an adjustable rev limiter be added, just by cutting spark above a user-set rpm?
Old Jan 7, 2007 | 03:13 PM
turbo2ltr's Avatar
That would be a feature of the ECU, not the PocketLOGGER software..
Old Jan 20, 2007 | 06:44 PM
gxl90rx7's Avatar
I get the lost connetion "X" when trying to change the timing values rapidly.
also, Is there anyway to change the timing values other than clicking the up or down arrows? I tried using the number pad, but it doesnt work. It just gets very tedious when making a lot of changes. Maybe add a slider to the side of the screen or enable the numberpad?
Old Jan 21, 2007 | 03:42 PM
edomund's Avatar
Bastardized RE AE
I get that also it's like the rtek needs a second to update the ecu or something. Also with the lost connection thing sometimes I will turn the key on and the rtek won't detect a connection. If I turn it on and off it will then detect a connection most of the time.
Old Jan 21, 2007 | 05:08 PM
turbo2ltr's Avatar
The new software should be more robust in the connection department.
You can use the "hard" page up/down buttons to make corrections on any table.
The reasoning behind not putting a slider for the timing table because timing changes should be done in little increments. Having a slider, its very easy to inadvertently make a large change..in the wrong direction.
Old Jan 28, 2007 | 02:18 PM
edomund's Avatar
Bastardized RE AE
Being able to use the hard buttons will be a very nice feature. It is sometimes hard to tap the little buttons with the stylus when tuning on the fly.
Old Jan 28, 2007 | 02:21 PM
turbo2ltr's Avatar
You already can. The hard buttons have changed corrections since the beginning. You can also use them to flip between the graph and number view when datalogging.
Does anyone actually read the manual?
Old Jan 28, 2007 | 04:44 PM
gxl90rx7's Avatar
read the manual?? are you crazy?
Old Jan 28, 2007 | 11:48 PM
edomund's Avatar
Bastardized RE AE
ahhh yeah I must have missed that in the manual.
Old Jan 29, 2007 | 12:17 PM
turbo2ltr's Avatar
Funny cause I'm working on the manual for version 2 this week...
Old Feb 7, 2007 | 09:29 AM
gxl90rx7's Avatar
ive been seeing a problem with injector duty cycle display when looking at logs. sometimes the it is doubled on the palm (for me it usually is ~35% max, it will show ~70%), but then you transfer it to pc, it is back to normal again, showing 35% max. Then i go back and look at it again on the palm and it is back to 35%. either that or i am crazy
Old Feb 7, 2007 | 09:44 AM
turbo2ltr's Avatar
Are you sure you arent looking at two different points...possibly before and after the secondaries come on?
Old Feb 7, 2007 | 10:03 AM
gxl90rx7's Avatar
im sure, because i have never logged d/c above mid 30's, so it scared me when all of the sudden the log showed 40-70%, but then transfered it, and it was back to 20-30
Old Feb 7, 2007 | 10:06 AM
turbo2ltr's Avatar
And you sure you arent confusing duty cycle and pulsewidth? Do you have the Palm and the viewer both set the same way? (to display DC instead of PW)
A mid 30s DC is extremely low.
Old Feb 7, 2007 | 10:14 AM
gxl90rx7's Avatar
Im pretty sure i have it configured for D/C.. i will have to check when i get home. but it has always been low like that, even though i have ~0% fuel correction right now
edit: check out these logs:
https://www.rx7club.com/attachment.p...hmentid=199268
~31% at 7 psi
Old Feb 7, 2007 | 06:20 PM
Oogly Boogly's Avatar
Will this interface work with windows mobile? that would pretty sweet to talk on the phone than tune...
Old Feb 7, 2007 | 08:46 PM
edomund's Avatar
Bastardized RE AE
Pretty sure it's written for the Palm OS.
RX7-RR
Introduce yourself
8
Jun 10, 2018 11:40 AM
subeone
Introduce yourself
6
Sep 19, 2015 12:07 PM
