losing boost at high RPM
Old Jul 18, 2006 | 07:14 PM
doduong11's Avatar
hey guys i just wanted to know if you guys know whats is wrong and how i can fix the problem.
Well i just got the car recently and i have never taken it above 4k RPM but today i tried and i notice losing boost at high RPM so i was wondering what might be the cus?
Well i was in 3rd gear at about 3.5rpm when i floored it the boost gauge jumped up to about 12psi and all of sudden at about 4rpm it dropped down to about 6psi and stay there. It did this couple of times so i dicided to do it in a lower gear. I slowed down put it in 1st launch it, boost jump to 12psi with no prob, in 2nd boost jump to 12psi with little hesitation, and in 3 boost jump to 12psi and stay but with little jerking, so what might be the problem here?
When i bought the car, the car has a TurboTimer, HKS F-Con and Downpipes and exshualt. Even though the car has a HKS f-Con it is not tunn yet.
Also how do you know if you clutch is wearing out? Mine's is taking off a little slow at low rpm like around 1k-2k in 2nd gear is that a sign?
Do i need to change the LSD at all? when i bought the car the right rear outter side of the tire is bald, everytime i step on the gas the car seems to want to go into a drift with the right rear wanting to slip to the right. But after i change the tires and get it align it seems to be ok now so do i still need to change the LSD cus i also notice a lack of power too.
thanks for all the help guys
Old Jul 18, 2006 | 07:44 PM
salva's Avatar
Rotary Restorer
Check your secondary turbo for leaks, lose vacum hose to charge control solenoid or valve etc.
Old Jul 18, 2006 | 08:16 PM
dgeesaman's Avatar
I agree it sounds like you're not getting proper secondary boost. Secondary boost begins at precisely 4500rpm.
I suggest going thru the Mazda troubleshooting listed on www.fd3s.net/boost_test.html.
Which lancaster are you in?
Dave
Old Jul 19, 2006 | 03:55 PM
doduong11's Avatar
thanks alot guys as soon as i get home tomorrow i'll check on that with my friend. Now this means i have to take a lot of stuff apart right. Which way or what part i should not take out to check for these leaks.
Oh by the way i'm in Lancaster PA
and thanks alot for the advices guys
Old Jul 19, 2006 | 04:31 PM
dgeesaman's Avatar
Well you're local enough that I'd be happy to try and help.
Dave
Old Jul 22, 2006 | 09:33 AM
doduong11's Avatar
oh you serious Dave
you think you can hook me up with the number so i can call you?
thanks alot man i appreciate your help so much.
Old Jul 22, 2006 | 06:21 PM
WaLieN's Avatar
Call me gramps!
Dave, what a class act you are.
Old Jul 22, 2006 | 06:44 PM
dgeesaman's Avatar
He's gonna owe me beer though
Old Jul 23, 2006 | 07:13 PM
doduong11's Avatar
how about a keg, is that enough? hahaha just make sure yyou finish helping me first not the beer hhahaha
Queppa
Nov 18, 2024 03:47 AM
Skeese
Adaptronic Engine Mgmt - AUS
65
Mar 28, 2017 03:30 PM
