Harness ? (where does this go)
Old May 23, 2006 | 04:33 PM
Question Harness ? (where does this go) please help
I'm dealing with the part of wiring harness thats under the manifold, and theres one black plug that I can't figure out where it goes. I searched but couldnt find any thing, probly b/c the question is so dumb, but hey I'd rather look stupid than stay stuck on this damn plug.
Old May 23, 2006 | 04:59 PM
I'm thinkning it must be on the manifold or the alternator but I'm not seeing it, and I lost my short term memory or something cuz i took it off only 2 days ago
Old May 23, 2006 | 05:16 PM
lnlycrpr's Avatar
always searchin
that right there is your Oxygen sensor plug. it reaches towards the back of your engine and plugs into the oxygen sensor out of the down pipe
Old May 23, 2006 | 05:19 PM
thank you very much, life saver
Old May 23, 2006 | 05:48 PM
I'm not sure but i dont thinks its the Os sensor, therres another pug real simialr that fits the o2 sensor, this one doesnt , this one is more circular.
Old May 23, 2006 | 05:59 PM
the first one is the 0s i belvie and the second one is the mystery plug. It is at the very end of the harness, there one green one with a clip, there 2 that go to the fule theres a ground and theres this last black one that i cant figure out.
Attached Thumbnails Harness ? (where does this go)-p1020269.jpg   Harness ? (where does this go)-p1020270.jpg
Old May 23, 2006 | 07:18 PM
can anyone identify that for me please
Old May 23, 2006 | 09:00 PM
lnlycrpr's Avatar
always searchin
hhmmm, yeah i was wrong about the oxysensor. sorry bout that.
is that plug coming out of the harness alone/by itself or is there a squarish plug about the same length with it/next to it.
look at the back of your waterpump housing. there should be two sensors. there should be a squarish one and a round one. the squarish one is the water temp sensor (the socket should have a little metal clip). the one your holding (if i'm correct) would be the aux temp sensor (like a fan switch), it sits right next to the temp sensor.
if its not that, then i'm stumped. thats all i got man
Old May 23, 2006 | 09:12 PM
that sounds right im running out there right now
Old May 23, 2006 | 09:44 PM
I'm looking there but I must b blind I cant see it, its gotta be that though, but you say its right next to it. idk
Old May 24, 2006 | 11:44 AM
could it be in a diff place on a S5 or not connected at alll, or what would be the effect of not having it connected
Old May 25, 2006 | 06:22 AM
lnlycrpr's Avatar
always searchin
well, if it is the aux switch, then dont worry about it. i broke mine off while fixing my waterpump. it is really only for the A/T models. just make sure that it is in fact the aux switch. i have an S5 turbo, and didnt need it at all.
is the water temp plug (squarish one) next to it??? post a pic of the wires that come out with it. i'll take a look at my 7 double check and i'll get back to you on that.
Old May 25, 2006 | 09:02 AM
Aaron Cake's Avatar
Engine, Not Motor
What is the wire colour? This is an S5, right?
Old May 26, 2006 | 02:12 AM
well its all good i did w/o it, i hope it wont matter I got the motor in and all set I was tring to start it up but got the cops called on me. Same guys that came last night too when we were useing air tools. lucky this cop loves cars he use to have a shop and has a supra so instead of a ticket he just helped me move my car back in the garage. This was the first cool cop I have ever met. The cop and my buddy think it wont start due to a timing issue, its not flooded I know that fuse trick and it got soo close. its started up but died after a few secs 3 times. will check on what to do about timing but the cop said i gotta stop for tonight
Old May 26, 2006 | 02:49 AM
str84wardchuck's Avatar
that's cool about the cop man lol
Old May 26, 2006 | 03:25 AM
slpin's Avatar
7th Heaven
if it started then died after a few seconds... check afm or vac leak.
Old May 26, 2006 | 04:56 AM
ok will do, gotta wait a few more hours, I triple checked my hoses but i will check agian just will check over everything
scissorhands
Sep 16, 2015 01:25 PM
