damn car won't stay running
Old Nov 24, 2002 | 03:16 PM
Moxeys93RX7's Avatar
ok i just did a bunch of stuff on my 88 t2. removed all the emissions stuff, new injectors and o-rings, new fuel lines, TID, TB mod. now the car wo n't stay running. it will start up (but turns over for a while first and i have to floor the gas pedal). when i do that it will rev to 5k then cut out like it's not getting fuel. no matter how much i rev the throttle it won't stay running. the injectors i put in were low impedence (it's all i could find) so i put the resistors in with them. when im just normally cranking it doens't really feel like im getting fuel pressure at the lines. i jumpered the fuel pump relay and i can hear the fuel flowing, hear the pump pumping and i can feel pressure when i squeeze the line. right now my battery is dead so im going to have to mess with it tommorow. anyone got any ideas on anyhitng else to try?
Old Nov 24, 2002 | 05:06 PM
someone help me out. i got to get the damn thing running so i can get the $ from the tow truck driver that screwed up my tranny (or at least will think he did)
Old Nov 24, 2002 | 05:16 PM
Piranha's Avatar
what 7
reconnect your AFM Thats what it sounds like anyway. That or a major vacuum leak.
Old Nov 24, 2002 | 05:32 PM
HAILERS's Avatar
HAILERS
Huge air leak? Small vac hose won't do what you describe, but if you forgot to reconnect the brake booster vac line at the back of the throttle body, that would cause the described problem.
But then again you did several things. The TID???? and the throttle body mod are other good areas to look at. Open hole somewhere etc.
Old Nov 24, 2002 | 07:34 PM
brake booster line is hooked up. TID is 2 pvc elbows and i know there not leaking. the throttle body isn't leaking either. it seems to be more of a fuel problem than a vacum leak. im going to double check everyhting tommorow
Old Nov 24, 2002 | 07:39 PM
SonicRaT's Avatar
Super Raterhater
Well, while someone is cranking the car, gently (and slowly) press the AFM in, if it starts and will idle as you hold it in, it's a vac leak. (meaning the flapper door on a s4 or the slider on a s5, have to take off the filter for this obviously)
Old Nov 24, 2002 | 08:41 PM
u mean move the flapper door (it is an S4) in as if air is flowing in?
Old Nov 24, 2002 | 08:51 PM
This is my vacum setup now
Here is my current vacum setup ( im pretty sure that's it i've had about 8 hours of sleep in 3 days). Anyone see any problems?
Old Nov 24, 2002 | 10:09 PM
come on guys i got to get this fixed
Old Nov 24, 2002 | 10:23 PM
SonicRaT's Avatar
Super Raterhater
Yes, as if air was moving in, just open it up slowly and see if you can get the car to start.
Old Nov 25, 2002 | 12:40 AM
i can get the car to start. i have to floor it and crank it for a while but it does start everytime. when i do that it will rev to 5k then die no matter if i hold wot or try to rev it. nothing will keep it running
Old Nov 25, 2002 | 12:55 AM
600HP CLUB's Avatar
i had this problem with my brothers n/a, we didn't have a filter so we used a rag and some zip tie, and soon we couldn't start it and **** u describe but we had a whole lot of smoke, then we found out that the rag is stuck inside the manifold, so make sure u didn't get something stuck between the air filter and throttlebody/ manifold when u did a TID.
and did you do the TB mod correctly? double check the secondary throttle shaft hole if its filled in correctly.
if fuel is coming in and u think ur not getting any, check the filter.
-mike
Old Nov 25, 2002 | 01:04 AM
SonicRaT's Avatar
Super Raterhater
Again I asked did you try to get it to stay running by holding the flapper door open? Just have someone crank it over and gently press the flapper door open slowly and see if you can get it to start, and if it does start push it in a little bit more and see if you can get it to stay running, if it does stay running you'll notice if you push too far or too little it'll run for ****, but give it a try.
Old Nov 25, 2002 | 06:31 PM
i tried the flapper door thing and it didn't work. it was actually starting harder this morning. i pulled everythign back apart and im going to try it again and see if i mised anyhting
Old Nov 25, 2002 | 06:47 PM
ok one last question (i hope) what is the thing that attaches to the throttlebody that goes down by the turbo it. when the throttle plates open it moves the rod that opens or closes somehting down near the turbo. it attaches to the front of the trottle body with a cotter pin.
Old Nov 25, 2002 | 07:39 PM
bump
rotor_veux
46
Jun 12, 2018 10:39 AM
alphawolff
Nov 17, 2015 05:57 PM
meat_whistle
Aug 12, 2015 08:41 PM
