oil pan removal
Old Nov 18, 2009 | 01:08 PM
sheldement's Avatar
oil pan removal
Okay. I'm trying to remove my oil pan on my 93, but the cross member is in the way of the whole front row of bolts. do i have to unbolt the engine and jack it up or what? Thanks.
Old Nov 18, 2009 | 01:14 PM
widebodyseven's Avatar
Formerly widebodyseven
I had this problem a couple months ago...
What i did and the only way i could figure out how to take out the pan was to jack up the engine with a hoist and unbolt the cross member and pull it down as far as it could go bc you could unbolt the screw but you need alot of room to take the pan out.
For me pulling the oil pan was the hardest thing to do.
Mahjik's Avatar
Mr. Links
You'll have to undo the engine mounts anyway to remove the oil pan. You'll need to support the motor somehow whether that's a jack from the bottom (without interfering with your oil pan work) or an engine hoist. Also, you'll find it easier to drop the subframe to have enough room to work on the oil pan while it's in the car.
Old Nov 18, 2009 | 01:17 PM
I had my car on a lift when i did this so i got to use a long 2 by 4 to hold up the engine while the frame was off
Old Nov 18, 2009 | 02:25 PM
DaveW's Avatar
Racecar - Formula 2000
Oil pan removal CAN be done with the subframe still in place. I did mine as described in the link below:
https://www.rx7club.com/showthread.p...easier+oil+pan
Old Nov 18, 2009 | 02:27 PM
Mahjik's Avatar
Mr. Links
No one said it couldn't.
Old Nov 18, 2009 | 04:50 PM
Sgtblue's Avatar
Urban Combat Vet
----------> http://www.harborfreight.com/cpi/cta...emnumber=96524
Old Nov 18, 2009 | 08:46 PM
sheldement's Avatar
I would like to thank everyone for all of the advice. I shall read over all of it several times before proceeding over thanksgiving break. (i'm in college)
Sheldon
Oh, i'm also working in the yard with a couple of jacks. ...this might prove to be interesting.
Old Nov 18, 2009 | 11:16 PM
pomanferrari's Avatar
don't remove the sub-frame but leave at least two of the bolts in (one on the driver side, one on the passenger side). Go get a tap 12mmX1.5 and retap the threads for the subframe bolts.
I used an engine hoist as it was easier to reposition the engine up and down.
Old Nov 19, 2009 | 01:33 AM
grimple1's Avatar
Turd Ferguson
I did my pan replacement with the engine still in along with the subframe. Here's how I made it work.
1. I took off the exhaust manifold/turbo/downpipe (my car is single turbo).
2. Put the front of the car up on jack stands.
3. Placed a floor jack with a block of wood just behind the crossmember on a solid piece of the transmission.
4. Jacked it up til it was snug.
5. Removed the motor mount nuts (which have to be removed anyways)
6. Jacked it up until the engine/transmission hit the transmission tunnel.
7. Remove the pan bolts.
8. Slide pan out exhaust manifold side.
9. Install was a repeat of the process.
* I did have to unbolt the oil sending arm within the oil pan with the pan dropped. It's not a lot of clearance but if you're patient you'll get the arm off.
All in all, it's a process I hope to never do again with the engine in the car. Can be done but is one of the biggest PITAs.
EDIT :::
If you drop the subframe DO NOT PLACE YOURSELF UNDER IT WHEN YOU ARE DROPPING IT. Be sure that you have something in place to catch it. IT is heavy. Don't injure yourself... stay clear of it.
Old Nov 19, 2009 | 01:36 AM
grimple1's Avatar
Turd Ferguson
oh and I installed the Banzai Oil Pan brace w/ studs on the re-install. Much better than OEM.
Old Nov 19, 2009 | 07:50 AM
sheldement's Avatar
Thanks grimple. That sounds like what i originaly had in mind for trying. I really don't want to mess with the subframe.
Old Nov 19, 2009 | 09:19 AM
Mahjik's Avatar
Mr. Links
You don't have to remove the subframe. Partially unbolting it will allow you to get you several inches for clearance (i.e. leave the suspension connected).
Old Nov 20, 2009 | 04:29 PM
pacman74's Avatar
Originally Posted by Sgtblue
This is the exact same horizontal engine brace I bought and used. I got it when it was on sale ($10 cheaper) and I think it was $50 well spent. It works great.
When I recently re-sealed my oil pan, I just took the whole front subframe off while the engine was held up with the horizontal engine brace mentioned above. Honestly, it's not as bad as it looks, it's not something that takes 30 minutes to complete, but it's not all that hard to do either. Unbolt the power steering rack from the subframe, mark the position of the alignment bolts that go through the lower control arms and then remove the bolts, and then remove the bolts that secure the subframe to the frame rails. The lower control arms will come out of their place in the subframe as you lower the subframe down. That's it. As much room as you would ever want to deal with the oil pan. (Note: I used my air impact wrench which probably made removal easier/quicker)
I reinstalled with a new oil pan, "The Right Stuff" gasket maker, Garfinkle oil pan brace, and the moroso stud kit.
FD7KiD
15
Feb 26, 2021 10:12 PM
rocker1337
16
Sep 6, 2015 11:28 PM
FD7KiD
Aug 17, 2015 11:50 PM
