(DRIVETRAIN) Small axles Vs. large axles
Old Feb 21, 2008 | 09:34 AM
andreyiv's Avatar
Hey guys, I have a newbie question. I heard that there are "big axle" and "small axle" first gens. Which model had which (GSL/GSL-SE)? Is the difference only in axle diameter or is there a difference in the spline diameter also?
Thanks in advance.
Old Feb 21, 2008 | 09:55 AM
Re-Speed.com's Avatar
1970-1983, Small Bearing, Small Spline. Rx2, Rx3 had LH and RH axles that were different lengths. SA cars were same length both sides. All were 4x110mm bolt pattern.
1984-1985 12A, Big Bearing, Big Spline. 4x110MM bolt pattern
1984-1985 13B (GSL-SE), Big Bearing, Big Spline. 4x4.5 bolt pattern. Longer than 12A axles from the bearing to the wheel mounting surface.
1981-1985 Housings are all the same lenght from flange to flange.
-billy
Old Feb 21, 2008 | 11:41 AM
andreyiv's Avatar
So the splines are all the same for non turbo cars in '84 and '85? Is there any difference in the splines between the GSL and GSL-SE?
Thanks.
Old Feb 21, 2008 | 12:31 PM
Thanks.
Turbo? Splines are the same for 84-85, SE or not.
Difference? Depends on the year break down listed above.
-billy
Old Feb 21, 2008 | 12:42 PM
MattG's Avatar
MattG FTW!!!!!
Great Info here billy!
I was looking for this info a week ago, I searched the archives, but couldnt find any info.
Im sending a PM to jon to try to get this in there.
-Matt
Old Feb 21, 2008 | 03:38 PM
David Dewhurst's Avatar
Matt, for future reference loot at http://www.mrmazda.no-ip.com/
Old Feb 21, 2008 | 03:40 PM
gsl-se addict's Avatar
Super Moderator
Also this thread is great and should be in the archive too:
https://www.rx7club.com/showthread.p...ht=axle+spline
Old Feb 21, 2008 | 05:35 PM
Rx-7Doctor's Avatar
Archived-https://www.rx7club.com/showthread.ph...ht=axle+spline
