RX-7 Store Questions for the RX-7 Store about parts, orders and Group Buys.
AEM Water / Methanol Injection Kits In Stock
Old Aug 23, 2007 | 04:02 PM
Jason's Avatar
The one
AEM just released their Meth kits. Here is some info on them.
Water Injection Kit
For use with gas engines with Forced Induction
The Water Injection Kit is a safe and economical way to reduce air inlet temperatures to increase boost pressure for more power. Lower air inlet temperatures allow users to advance timing without having to run higher-octane fuel. This is the most complete kit available on the market straight out of the box- no additional parts required.
WATER INJECTION KEY FEATURES:
• Universal kit includes everything you need for installation
• Progressive, controller-driven 150 PSI pump
• One-gallon tank with integral fluid level sensor
• Dash light for system status and low fluid warning
• Alcohol Compatible (up to 50% in solution with water)
• Progressive controller, provides boost-dependent
variable flow
• Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
• Includes three jets to match your power requirement
Part Number- 30-3000
We ship these express at no extra cost.
http://www.rx7store.net/product_p/aem%20alky%20kit.htm
Old Aug 24, 2007 | 02:12 PM
Mister Destiny's Avatar
Keep it Easy
I'm ordering it today!
Old Sep 5, 2007 | 02:26 PM
Keep it Easy
Took less than a week to get it.
Thanks, Jason.
Old Feb 18, 2008 | 01:13 PM
Keep it Easy
i finally put it on the car and it works just as i imagined
Old Aug 13, 2008 | 11:18 PM
Bradrx7400's Avatar
Bradrx7400
Would water injection on a stock FD3s do anything to boost mileage with pump gas?
Old Aug 13, 2008 | 11:19 PM
Bradrx7400's Avatar
Bradrx7400
I should probably research this more.
Old Aug 13, 2008 | 11:21 PM
Bradrx7400's Avatar
Bradrx7400
I noticed that airplane engines work a lot better when its rainy and high moisture
Old Aug 31, 2008 | 12:23 AM
wajiguqu0223's Avatar
Smile police inquiry
commonwealth police inquiry in 2005, Palin herself had accused Wooten of threatening to hurt her parent during the breakup of her sister's matrimony. (The Palins claimed, among different things, that Wooten had victimised a eve isk taser on his 10-year-old stepson, and dig a cervid without a permit.)Since Monegan prefab his allegations, Palin has denied that she personally had a part in the exertion to discharge Wooten. On July 28, the dos legislative council, a bipartisan committee of senators and representatives, decreed a specific organisation to penetrate the weigh.
Old Jan 6, 2009 | 06:18 PM
510_rx7's Avatar
was it difficult to install? was plannin on gettin 1
Old Jan 6, 2009 | 07:13 PM
Keep it Easy
easy to install and i can hook you up on where to get it done
Old Apr 26, 2009 | 08:14 PM
jonnyrx7's Avatar
ROTARY PUNX
will this work combined with a pettit ecu?
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
FD7KiD
Aug 17, 2015 11:50 PM
