IS Big power on S5 TII engine Possible ?
I'm talking 600 plus to the ground. Is this possible with the S5 TII engine with a 3rd gen rear iron ? Of course porting will be done too.......
I'm debating whether to use a S5 TII engine or a 13B REW engine.
I have access to a TII engine for a great price so I'm leaning more towards that.
Thanks.
Thanks.
Depends the S5 and FD shared the same rear iron. Some have the hardened rear and some have the hardened rear with triangular reinforcement same as FD. This option is a crap shoot but there. The housings are the same outside of spark plug casting. So is the motor any less potential prone? No I do not feel it is. If you have any concern of if none I still suggest the use of cryogenic treatments of the motor with studs.
So, which engine is prone to breaking rear irons? Is it the S4 TII ? I thought the S5 TII had the same problem.
The engine that I have access to has already had the rear iron replaced with a FD rear iron. Kevin Landers apparently did the rebuild.
Thanks.
Thanks.
Thanks.
Thanks.
Yes the S4. In the end it all points to detonation and pore tuning. Running studs great enhances the amount of lateral torsion the motor can withstand before flexing the plates. However the pinging seen from early explosion is thousands of lbs of force far greater then just the power output torsion.
Trending Topics
Eric, from talking to many engine builders about my set up and even running a small shot of nitrous, none of them said it cant be done on s5 block. I did have my rotors race clearanced, thanks to atkins DAN,. u should be fine
Alright, I'll buy this S5 block and give it a LUPE rebuild. Should be fun boosting the world at it.
Want to make it a race to 600?...
Anyways, good luck!
why hasnt anyone mentioned that the FD ports and TII ports are COMPLETELY different? the FD ports angle upwards and are in a different spot on the outside of the iron. also, the TII manifold wont work with an FD rear plate.
I've already done it......... It's nothing new to me
The P ports on the s5 are actually 10degrees earlier opening and 1mm wider then the FD P port. The secondary FD port is only 10deg earlier opening then the S5.
And on his engine build going for 600+whp do you think the stock ports are going to be used? The OEM ports mater about as much as a turd in a punch bowel to him.
Originally Posted by iceblue
Because what you believe is not so.
No offense sorry but that is incorrect. The dowels are identical to all 13b engines. The s5 rear iron has the same larger runner as the s5 front. Some s5 rears had identical castings to s4, some had the same size casting with a triangular reinforcement from the dowel to the oil filter pedestal, some s5's even had a much larger casting (same as the fd casting) plus the reinforcement.
As far as the runners ehh port them some.
