found sway bars for cheap, good? or too good to be true?
i found sway bars for 50$ can these be crap or is it a good price, dont know who the manufacturer is, ill check and post it tomororw.
If it bends or breaks once you have it installed, it means they aren't good quality. Or worse still, if it breaks or bends when you handle it, prolly won't be very good in the car. Ask the manufacturer how much they weigh and compare with companies like Cusco, ST, or whoever else makes expensive ones -- chances are if the weight is close and it's made of steel or aluminium, should be close to the same quality. My guess is that these are functional, but don't look fancy like more expensive ones.
need RX7
11
Aug 19, 2015 08:27 AM
