blow-thru weber info needed
Guys I'm compiling info for a turbo-weber-blow-thru application...got any good leads?
I know about the mailing lists...
thanks
thanks
hey direct thanks...
I have seen those 12a to 13B exhaust manifolds adapter plates you know who sells them? I searched but nothing...
anybody has a link to a some nice water to air intercooler setups?
also a link to a good malpassi dealer.
...I guess you see my plan...
TIA
TIA
Trending Topics
I can has a Hemi? Yes...
Gone Race'n
on
The most difficult challange I had was the turbo manifold. What I ended up doing was cutting the mounting ears off of a T2 manifold and then welding it to a 12a header plate (header flange). I double welded it (ground down the first welding and then welded back over the top) This spaced the turbo out just perfect for the wrap around style manifold. I did have to grind a little off of the area where the top down pipe stud is. Other than that it fits perfet, almost like it was supposed to be!!
Ryan
Ryan
Hunting Skylines
on
Hey moremazda, nice set up you got there... think you could give me some specs (fuel system, carb mods? boost, ignition, etc)? I'm considering doing something like that with my IDA.
Any finished pics?
Any finished pics?
Gone Race'n
on
Originally posted by Directfreak
This is not finished yet right?
There are no mods to the carberator. Only the jetting has been/will be touched.
Ryan
Seven Is Coming
Hey I just thought of something...Do you have to take the emissions off when you put a DCOE carb on there like that? I mean, wouldnt it hit the rats nest? Well, now that I think about it...Who would want to run a Weber DCOE and aftermarket exhaust with a rats nest still intact .
~T.J.
~T.J.
