(REFERENCE) The Upgrading a Stock Rx-7 Thread
Old Aug 28, 2006 | 01:39 AM
  #76
trochoid's Avatar
Old Fart Young at Heart
Start with the FAQs at the beginning of the forum. Do lots of reading, go through the archives for how tos and the FSM link in my sig line.
Welcome to the forum.
Old Aug 28, 2006 | 01:51 AM
  #77
Naegleria_Fowleri's Avatar
Terrified.
Thanks Trochoid for finding this. I'm so sick of reading these new threads that all say the same thing, "How can I get more power out of my rx7. I'm a newbie!"
Old Oct 1, 2006 | 02:30 AM
  #78
RW-7's Avatar
Moderating the Trochoid
Remove That Spare Tire
Old Oct 1, 2006 | 01:29 PM
  #79
dean23's Avatar
pwned
remove movies like fast and furious from your brain.
Old Oct 1, 2006 | 06:06 PM
  #80
mjm4jc's Avatar
84 SE
Throttle body mod.
[QUOTE=JIMMY54]Throttle body mod. (fuel injected cars)
Lowers air intake tempuratures DRASTICALLY (coolant line is removed of intake and re-routed back into block, and improves throttle response, and will maintain a perfect set idle. also a pair of butterflies are removed, more air flow.
Draw back is you lose your mechaincal choke so car will run a tiny but rough in cold weather till car reaches operating tempurature.
Under 10 bucks to do, or possibly free if you have basic things needed for this 1-2 hour job.
Pro will take about 45 minutes to complete and restart the car.
Can you give me any details on how to do this? I am a little confused, because you say that this is for FI models, but then you talk about losing the mechanical choke.
Old Oct 1, 2006 | 06:28 PM
  #81
trochoid's Avatar
There are a couple of ways to do it, one keeps the warm up cycle. I did it on my 2nd gen and hated sitting on my *** until the engine warmed up enough to drive off. I eventually went back to stock.
The tb mod is of most benefit for the TIIs, for the NAs there is little gain and for me, keeping the warmup cycle is worth more than a couple of hp. You will find more info on it in the 2nd gen section.
Old Mar 1, 2007 | 05:59 PM
  #82
TSC_1's Avatar
Newbie
But why? We all know ten second Jetta's are abundant. :P
Old Mar 1, 2007 | 06:06 PM
  #83
TSC_1's Avatar
Newbie
If you want even more torque, add a LSD. This will seriously help with getting off the line as well as getting sideways for all you drift fans out there. I personally recommend a 1.5 way.
Old Apr 3, 2007 | 03:10 PM
  #84
unleashedrx's Avatar
hey did oil change and plugs helped alot now im doing a rats removel
Old Apr 3, 2007 | 05:23 PM
  #85
tigermack's Avatar
CPS Motorsport
Subscribed.
Old Apr 3, 2007 | 05:29 PM
  #86
tigermack's Avatar
CPS Motorsport
Subscribed.
Old Jun 23, 2007 | 10:35 PM
  #87
blackspade13's Avatar
piston vs rotary? Rotary!
thanks for the ideas, ill keep them in mind
Old Jun 24, 2007 | 08:18 AM
  #88
redfb's Avatar
king of randomness
i don't know if anyone mentioned a mazdaspeed short shifter, i have one and it doesn't help it go faster but helps with the lags in between shifts to keep going faster. Also can anyone give me CP racing's website?
Old Jun 24, 2007 | 08:52 AM
  #89
redfb's Avatar
king of randomness
oh and bonez stage 1 brake upgrade help you stop faster...at least they did for mine but i think they weren't installed correctly so i am investigating into that one
Old Jun 24, 2007 | 09:18 AM
  #90
1stgenNutt's Avatar
If your rebuilding
if your rebuilding your enigne use 83-85 rotors and fly wheel & counterbalance
Old Jul 9, 2007 | 08:11 AM
  #91
GTX79's Avatar
Super Shooter
Okay, I looked everywhere I could, but didn't find what I was looking for, so I was wondering: Is it possible to turbocharge an N/A 12a with a nikki carb and just run it at about 5psi of boost? I was told that it was possible with just a bolt-on setup using a KKK K03 turbo, some oil and coolant lines, and the proper intake/exhaust piping. don't feel like going through all the trouble of a full engine swap. Any suggestions? I hope I'm asking the right folks about this stuff...
Old Jul 9, 2007 | 03:30 PM
  #92
orion84gsl's Avatar
My 7 is my girlfriend.
CP Racing's website is no longer available. In fact they are no longer available, from what I've heard.
GTX79, search for blowthru turbo setups. You should find the info you need
Old Dec 13, 2007 | 12:11 PM
  #93
rydestandard666's Avatar
1980 V8 RX7
Drop a v8 in there
Ok maybe that wouldn't apply to upgrading a stock rx7
I have been told by rx3 drag racers that the stock 12a can handle a 150-200 shot.
A 50-75 shot might be a little more reasonable for something you need to rely on and I can't think of anything else this cheap that will give you this much more hp. Not to mention it's not hurting anything when your not using it.
Old Dec 15, 2007 | 08:29 PM
  #94
KetteringRotorhead's Avatar
Suffering Rotary Relapse
Make stock 7 faster, easy;
Pull out everything you don't absolutely need to go faster, turn faster, or stop faster.
Weight is the devil.
Lightening the car is fun, effective and free!
Old Dec 15, 2007 | 09:06 PM
  #95
redbstd's Avatar
Red 84 SE
How much do our cars weigh gutted any way. 1900-2100ish im geussing?
Old Dec 15, 2007 | 09:09 PM
  #96
Terrified.
^Try 2,300 to 2,500, iirc. That is probably dry weight as well. Even if it was 1,900 lbs, it could always stand to go on a diet. Every car can. Especially when we're talking about the go-fast department.
I didn't see that you put down gutted weight. I am sure that simply depends on how much you gut.
Old Dec 16, 2007 | 12:01 AM
  #97
redbstd's Avatar
Red 84 SE
i know the wieght of my SE iirc it was 2500ish i was talking completely gutted. someone around here has to have a gutted 7. if not ill do it to find out
Old Dec 16, 2007 | 12:49 AM
  #98
TeamSMS's Avatar
Weight redux does help out a lot but once all the free weight redux is done...spend some money on even more!!! Id say gut it, lightweight seats, lightweight wheels, flywheel, lose the a/c, p/s, air pump (once cat is gone), lexan glass...anything else on weight redux guys?
Old Dec 16, 2007 | 12:52 AM
  #99
84stock's Avatar
Install a Camden
Old Dec 16, 2007 | 12:53 AM
  #100
redbstd's Avatar
Red 84 SE
fiberglass/carbon fiber hood, fenders, hatch, doors. fab rear end, aluminum rad and shroud, fab control arms
