(IGNITION) DLIDFIS installed! Small write-up and some questions
Old Sep 7, 2004 | 08:31 AM
  #76
Mireck 12A's Avatar
Racingbeat dealer
Originally Posted by Jeff20B
Three J-105s!
Yep.... and because you stated they fail quite a lot (??? never seen one broken in 13 years but well....) I got 3 spare J105's in the car, together with the extra sparkplugcords.
Old Sep 7, 2004 | 01:12 PM
  #77
Jeff20B's Avatar
Lapping = Fapping
Pele, you saw the pics of the filed down male quick disconnects in the pickup plugs, right? They're never given me a problem.
Mireck, I must have stated that in the article. Man, I was so conservative back then! That's why I said to use shielded wire, you know, to be on the safe side. It turned out to not even be needed, as well less convenient than regular wire. I'm sure the J1-5s will last a long time. I even picked up a couple spares recently that'll go onto an engine eventually.
Old Sep 13, 2004 | 10:40 PM
  #78
Pele's Avatar
Right near Malloy
That's what I meant... Instead of having two points of failure, (the mag pickup to the ignitor, then the ignitor to the harness) I have one point of failure. (the mag pickup straight to the harness)
Old Jan 1, 2005 | 03:56 PM
  #79
Pele's Avatar
Right near Malloy
I think the longest pickup wires I've ever ran are probably up to 2 feet. It never had a problem with false triggers. I've never used shielded wire. I need to update my DLIDFIS article to mention this.
Doncha just hate it when you wanna post something and you forget it...
I do...
Thankfully I remembered what I wanted to ask... 4 ******* months later...
Do you have any problems with missed triggers due to the signal getting weak over the distance?
How long do you think you can make the wires before you do start having problems like that?
Old Jan 1, 2005 | 04:07 PM
  #80
Jeff20B's Avatar
Lapping = Fapping
Never had a problem with missed triggers. I have no idea how long the wires can be before problems arise. If you experience problems, Maybe you could locate the ignitors close to the pickup and run the B and C wires a greater distance? Use large guage wires. They are pretty much immune to electrical noise because B is always on and C is a digital on and off.
Old Sep 26, 2005 | 07:50 PM
  #81
nitros13's Avatar
Newbie
Hi guys, nick from australia here, i have just wired up the series 5 ignition coil as a direct fire system and it works GREAT!!! better power, fuel economy and resonse!!! thankyou heaps guys for the tutorial!
nick
Old Jun 20, 2006 | 11:27 AM
  #82
Mazdahead's Avatar
Fantastic Job guys! I made 2 of them, 1 for my 80 CSP car and 1 for my 85 SE which I am currently building for ITS class running hillclimbs. The 80 Fired right up with no problems and I will add some pics and results after running the pagoda hillclimb this weekend. Thanks for all of your effort!
Old Sep 6, 2007 | 11:14 AM
  #83
Rotary-Celica's Avatar
how do you guys feel this 3 ignitor setup will compare to the msd fired setup
http://www.smbaker.com/rail/msd6a.html useing 1 ignitor
sorry to bring thread back from the dead but this is the best thread I looked at
Old Sep 6, 2007 | 11:22 AM
  #84
Jeff20B's Avatar
Lapping = Fapping
That smbaker guy neglected a few things in his writeup. See if you can spot them.
Old Sep 6, 2007 | 12:10 PM
  #85
Siraniko's Avatar
RX for fun
without looking at that link, Im afraid to say that DLIDFIS works as good as MSD.
just kidding Jeff
Old Sep 6, 2007 | 01:22 PM
  #86
Jeff20B's Avatar
Lapping = Fapping
I sold my MSD 6AL for $150 a few weeks ago. I hadn't used it since '01.
Old Jan 20, 2008 | 05:45 PM
  #87
BigBadWolf's Avatar
FL DLIDFIS probs
Sorry guy's, must be an idiot.
Followed instructions, seemed pretty simple. Engine runs great, meter reads hot everywhere, but no tach and no keyed shutoff(I have to pull fuse to relay). It's an '83, and I got the box off an 80. I used to extra connector off box to plug right into lead BC to feed lead circuit. Flattened some pin connectors to fit in the pickup. I pulled the BC jack off the trailing, ran new wires to the coil, still attaching the Yg to the - on the T coil, and splicing in the condensor. I used the Bw wire to signal the relay, which according to the wire diagram in my Haynes is key +.
Help!
Old Jan 21, 2008 | 08:19 PM
  #88
BigBadWolf's Avatar
OK, wired up a little too much. Still can't get any tach, even switched trailing ignitor. Damn!
Old Jan 24, 2008 | 12:42 PM
  #89
KaiNalu's Avatar
Tach is fed from the Yg wire which should be going to the - on the Lead coil not the Trailing. That is assuming you don't have a MSD or Jacobs ignition system installed. The Yr wire goes to the - Trailing coil i'm pretty sure. You are correct on the Bw wire being the ignition hot. It sounds like you may have a constant power going to the relay which is causing your ignition not to work. I didn't implement a relay in my ignition so I can't say for sure but it may also be contributing to the switched trailing issue. Do you have both leading and trailing going through it? Hope that helps.
Old Dec 2, 2008 | 08:58 AM
  #90
statique's Avatar
Ok I just recently purchased an sa with a 12a turbo with 2 6al and 2 msd blaster coils would this set up make me give up my 6al or can I still use them and should I still use them...I've seen people run 4 6al's and run ls1 coils...have any clue why its done and how to do it?
Old Dec 10, 2008 | 04:06 AM
  #91
statique's Avatar
Bump!!!
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
alphawolff
Nov 17, 2015 05:57 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
