Final Pictures and Status of NA Turbo Install
Old Mar 16, 2002 | 10:25 AM
Silkworm's Avatar
Has been.. hangin' around
make this a sticky, it might save us from all the NA - T2 questions.
Old Mar 17, 2002 | 01:13 PM
FourtyOunce's Avatar
VKDAGREEK finished this N/A --> Turbo swap last year. I think he was the first to actually complete the task and run the car with 10# of boost with no problems.
As far as fuel pressure, you can use a RRFPR, which is boost dependent.
Old Mar 17, 2002 | 01:48 PM
Aaron Cake's Avatar
Engine, Not Motor
oh oh oh. my dream. stupid automatic convertible, my dog runs faster than it does.
How much did it cost you? How many parts, aside from the oil pan, did you have to fab?
Current cost is about $1300 Canadian, but that's only with the amount of work done as shown in the pictures. I still need to get the intercooler modified (relocate outlet), need some intercooler piping, a BOV, a downpipe and an S-AFC.
Aside from the oil pan, the turbo bracket was fabbed, as well a custom blockoff plate for the ACV. And then there's the intercooler piping, downpipe, oil/water lines, intercooler mounts, BOV flange and a few other MISC things.
So what are you going to do for coolant passing through the turbo?
Connecting it in series with the coolent feed to the throttle body.
is that turbo oil drain above the oil level in the pan?
Doubt it.
Heh, and I thought my garage was cluttered
You should have seen it BEFORE I cleaned it enough to get the car in there...
That's what I have been thinking of doing lately...
Old Mar 18, 2002 | 12:48 AM
  #29
aaron cake it would be better to splice the line going to the heater core than the line going to the throttle body
Old Mar 18, 2002 | 07:43 AM
  #30
rxrotary2_7's Avatar
Originally posted by vaughnc
Once you're done, my convertible needs one of these
nah, this is what your vert needs
this is a 91 vert. (or the way it should have been made) to make up for that extra weight
its not quite done yet. does start and run, but not up to par.
byw...nice job thus far aaron cake
Old Mar 18, 2002 | 08:38 AM
  #31
Xentrix's Avatar
Kill Bear
Keep us posted Aaron. Between my roommate and myself we've got enough extra parts to do this mod to my fc.
Old Mar 18, 2002 | 09:35 AM
  #32
Roy James's Avatar
My cars louder than yours
Sweet Milk!
Old Mar 18, 2002 | 10:21 AM
  #33
blu_gxl's Avatar
helz ya, now that's a project wish i could take my car off the road long enough to do that. could we get a running total as you go along please? and pics are great man
james
Old Mar 18, 2002 | 10:33 AM
  #34
peejay's Avatar
Old [Sch|F]ool
Everything I've read about turbo installs says the oil drain not only must flow downhill with no uphill sections what-so-ever, but also that the drain MUST be higher than the oil level in the pan. I suspect that's why the stock T2 has the drail in the front cover.
I don't see why it wouldn't work, but book wisdom says the turbo won't live too long, and will blow a lot of oil out of the seals in the meantime. Let's hope the books are wrong on this one...
Old Mar 18, 2002 | 10:40 AM
  #35
Old Mar 18, 2002 | 11:58 AM
  #36
Aaron Cake's Avatar
Engine, Not Motor
Why? I don't see the advantage...The coolant to the throttle is basically the same (right from the water pump to the block) and the hose is even the same size.
I'll see what I can do about the running total, but can't promise anything...
I can't see what it would matter that much...Gravity feed is gravity feed. Worst case is I need to relocate the oil drain...No big deal...I'll just tap the front cover if necessary.
Old Mar 18, 2002 | 10:19 PM
  #37
what are you doing with the stock tII intercooler? are you front mounting it? it would be much easier to use an isuzu npr intercooler.
Old Mar 19, 2002 | 12:28 PM
  #38
Aaron Cake's Avatar
Engine, Not Motor
I don't have easy access to an NPR intercooler, so I am having a welder relocate the outlet on the TII unit to make it front mount.
Old Mar 20, 2002 | 12:06 AM
  #39
Xentrix's Avatar
Kill Bear
Man, this was a couple pages in. It should be TTT
Vkdagreek
Can you explain how you modified the wastegate to fit without hitting the body?
Old Mar 20, 2002 | 12:09 AM
  #40
Felix Wankel's Avatar
Super Newbie
Technicially, its the wastegate actuator that hits. The wastegate is inside the turbine housing.
Old Mar 20, 2002 | 08:07 AM
  #41
Xentrix's Avatar
Kill Bear
Old Apr 25, 2002 | 12:12 PM
  #42
Aaron Cake's Avatar
Engine, Not Motor
Wow, look what I found using the search...
Old Apr 25, 2002 | 12:25 PM
  #43
TonyTurboII's Avatar
Glock Lover
Updates?
Old Apr 25, 2002 | 01:20 PM
  #44
Aaron Cake's Avatar
Engine, Not Motor
I will be posting some more in a week or so...
Old Apr 25, 2002 | 03:08 PM
  #45
yeah....updates!!!
Old Apr 28, 2002 | 11:01 AM
  #46
Aaron Cake's Avatar
Engine, Not Motor
Bump....Also, I will be posting updates within two weeks after I get my new digital camera and a little more work on the car done...
Old Apr 29, 2002 | 06:43 AM
  #47
Xentrix's Avatar
Kill Bear
Sweetness!!!!
Old Apr 29, 2002 | 11:28 AM
  #48
blu_gxl's Avatar
gettin a little low....ttt
mods could we possible get this stickied?
Old May 8, 2002 | 07:36 PM
  #49
Xentrix's Avatar
Kill Bear
TTT
Any more pictures?
Old May 9, 2002 | 04:37 PM
  #50
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
This is probably a bad idea. I haven't looked to see if this is the case on an FC, but MOST cars turn the flow of coolant off through the heater core when the temp selector is on the cool side.
Brad
