(ENGINE) Is this the sound of an apex seal gone bad?
Old Apr 16, 2008 | 09:25 AM
OneRotor's Avatar
RAWR
I'm going to call vacuum leak from the videos. It won't idle, but revs no problem. When I chewed side seals this past summer and started over-pressurizing my sump, the bastard wouldn't rev over 4k, and wouldn't run below 2k. I was puking oil out of my filler neck and fumigating the neighborhood. My current 7 is running like the car in your videos, and now that I've seen the diagram of the hose for the anti-afterburn valve, that's what I think my problem is. I'd search for a vacuum leak along with using the compression tester.
Oh, and for the record, Murray's sells a compression tester that has a button that is held down to release the pressure so you don't have to remove the valve, all you do is hold down the button and you're good to go.
Good luck, and if it's got good compression, happy hunting for the vacuum leak.
Old Apr 16, 2008 | 07:09 PM
ray green's Avatar
OK, the Fat Lady is singing and this truly is the sound of an apex seal going bad:
http://s259.photobucket.com/albums/h...=engmov004.flv
Here's Crit's home made compression tester, it works great:
It shows the rear rotor has a steady 1-2-3 compression beat. But the front rotor goes 1-2-pluff-1-2-pluff
Time to get cranking on the Silver One:
And thinking about just what kind of rotary engine to put in the White One.
Old Apr 16, 2008 | 08:06 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
Damn Ray, I hate hearing that
Let me know when you need her:
  #29
Glazedham42's Avatar
Resurrecting Gus
Well Ray, I don't know what else to say other than sorry about your luck. After everyone has had a chance to offer their condolences I'll archive this thread so that it can be used for future reference. Maybe this way the 12A didn't die in vain.
R.I.P.
Jamie
Old Apr 16, 2008 | 08:31 PM
  #30
ray green's Avatar
Damn Stu, that's the good one! That's the 12A from the Tan One! So you think we can put the White One 12A and the Tan One 12A and build a nice street port?
There's a moral to the story Jamie - don't think you can get away with not putting MMO in every tank of fuel.
And the news is all good. The White One will come back stronger than ever. And the Silver One needs some time out on the road.
The Silver One has an RB header, over sized tubes ending in a little Borla tin can, way too loud but really really fast. It was a garage queen in an earlier life, the thing hardly creaks (thank you Zach!). Can't wait to see what it does out on the highway.
Thanks for the help and suggestions folks! Whad'ya'll think I should put in the White One, stock or street ported 12A or some kind of 13B mongrel?
Old Apr 16, 2008 | 08:46 PM
  #31
Jeezus's Avatar
We could try. If you want a SP, I have not torn down the front oil leak engine yet. If we use that engine and the engine in your car we probably could. The one in the pic we can swap in so you can keep driving the white stallion.
When it comes to diagnosing parts, I leave very little lee-way on it. I have some papers here with diagrams/schematics/measurements on a quality rebuild, and some things on there (which will work great) leaves me a little edgy on using it.
Hey, why stop on a SP only? Do a Street/Bridge/Peripheral like I am messing around with
Old Apr 16, 2008 | 09:33 PM
  #32
mazdaverx713b's Avatar
Have RX-7, will restore
keep us posted on what you decide to do Ray. sorry to hear of your misfortune. what is the mileage of the current white car's engine?
Old Apr 16, 2008 | 09:48 PM
  #33
ray green's Avatar
146,000 or so on the White One, a mere juvenile. I don't know how Mike has kept his together for 250,000 plus without MMO.
I'm thinking turbo or something like Stu suggested.
Old Apr 16, 2008 | 10:32 PM
  #34
Delicious's Avatar
i thought a bad apex seal went 1-pff-pff-1-pff-pff
Old Apr 16, 2008 | 11:04 PM
  #35
Crit's Avatar
No distributor? No thanks
Ray, did you get a rough compression number for your rotor faces? If you get hi-hi-hi and hi-hi-lo, then it's likely a side seal. Blown apex seals are similar to a head gasket, in that two faces will exchange gasses under compression, so you'll get low compression on two faces rather than 1. Just a thought.
Old Apr 16, 2008 | 11:55 PM
  #36
Jeezus's Avatar
Yes. Side seals will still show 2 puffs instead of 3, where as an apex will show 1 puff.
Old Apr 17, 2008 | 06:21 AM
  #37
ray green's Avatar
OK then, it sounds like it is a side seal, not an apex seal. It is definitely a hi-hi-low cadence. I was wondering about that too. But does it matter? Is there a better chance I haven't totally destroyed the chamber?
The used turbo is a thought Joe, I'd have to think about the gas mileage though. After all, the main purpose of my 7's is commuting, not racing (which also rules out Stu's street/bridge/peripheral and Michael's 20B). Also I'd kind of like to take this chance to build an engine (with some help!).
Old Apr 17, 2008 | 11:18 AM
  #38
Box_Man's Avatar
I hate drum brakes
Use Mazda seals, solid corner seals (the rubber plug in the OEM one deteriorates, and might as well not be there after a few thousand miles), Clean and inspect rotor housings by wiping the sealing surface with an MEK (or gasoline) soaked rag to remove deposits, and Clean rotors in a bucket of 50:50 water/Zep industrial purple cleaner for a few hours and brush off carbon deposits. While you're in there, put in a turbo oil pump, port the oil pump passage, and shim the pressure regulators.
Oh, and PAINT EVERYTHING! I used a secret ghetto powder coat on my engine...
  #39
84stock's Avatar
It may be a good rebuild candidate since it did not toast an apex seal (which usually kills a housing). Take it out, take it apart, get the rebuild video and you're in school.
Old Apr 17, 2008 | 11:23 AM
  #40
Re-Speed.com's Avatar
Ray, we should have a Bridgeport install party for me and that may open up a stock 12A that needs a good home.
Although everyone who heard it this past weekend would swear it was a Bridgeport
-billy
Old Apr 17, 2008 | 11:28 AM
  #41
ray green's Avatar
OK I'm convinced, this is what my 12A will look like in a few months:
In the mean time I'll be driving the Silver One.
Donny that's a good question, I'm still not sure exactly how it would be used but doing the 110 mile a day commute at least once in awhile would be nice. I'm going to use this opportunity to learn about rebuild options and how to do it, the project will probably evolve as I go, especially when we crack it open. What it gets used for will probably depend on what we do to it.
I was imagining that broken apex seal wrecking havoc inside the chamber but maybe it won't be so bad if it's just the side seal (whatever that is).
I'll try to post a short movie of the compression test this evening for the record.
Thanks for the help guys!
Old Apr 17, 2008 | 11:57 AM
  #42
Crit's Avatar
Ray, I've got 1.5 engines taken apart in my shop, and the half is on my engine stand. You're welcome to come by after work and I'll walk you through what's what. I can even show you what I've collected so far for my first engine assembly.
Old Apr 17, 2008 | 04:54 PM
  #43
bad 83's Avatar
PSHH! PSHH! HEAR ME NOW?
Ray, with your longevity concerns, I'll suggest a mild street port. You can retain all your nice emmisions, and have a little more kick. As you well know, the more power you make, the more abuse you'll give it . Just check our last meet video.
Old Apr 17, 2008 | 07:05 PM
  #44
ray green's Avatar
Just when I thought I had it figured out, it starts to get interesting. I went out tonight to take a vid of the front rotor compression to show you guys, the one that was missing every third compression spike yesterday. So here it is tonight:
http://s259.photobucket.com/albums/h...t=DSCF1052.flv
Looks just like the rear one, nice steady even spikes.
I tend to be an optimist, but this stretches the imagination - has my 12A repaired itself?
It's been sitting for several days with the chambers soaking in Sea Foam. Do you suppose that side seal resealed?
I can't wait to clear the Sea Foam and see if it runs, but if it really is healing itself I figure I'd better do what I can to help with the recovery. So I squirted in another half can of Sea Foam according to Kent's directions, put the plugs in and gave it a few spins. I'll soak and spin and start it up tomorrow.
Anybody placing bets? What will we see tomorrow?
This:
http://youtube.com/watch?v=N7lGhIMeS0A
Or this:
Crit, I do need to take a closer look at one of your engines from the inside, I'm getting kind of curious about what's going on in there.
But now I've got the bug and I want to build a mild street port, like Sam says, maybe with or without the rat's?
We'll see what happens with the White One, I think she is trying to tell me something.
Billy, what's this about a bridgeport install party?
Here's Kent's suggestions, form another thread:
"Ray,
Yes, hi-hi-low = side seal. However, this may mean that you are in luck. Typically the side seals receive little wear (much less than the apex seals). They dont typically break either except in the case where people have done a bad port job and the edge of the side seal catches on the closing part of the port. It may be that your side seal is just gummed up with carbon and is not sealing properly. It might be worth another soak in seafoam and maybe running the engine with some seaform or mmo in the tank. Put seafoam down the carb, rotate the engine, add more.. squirt some in the spark plug holes with a turkey baster. Let soak for a few days. See if that will help.
Even though this might fix it, it might be a good time to pull the engine anyway. Once an apex seal gives, it takes out a bunch of parts with it. Better to rebuild before this happens. She has had a good life..time for a new heart perhaps. "
Old Apr 18, 2008 | 02:17 PM
  #45
ray green's Avatar
The compression seems to be fine, a steady three beat peaking around 90 lbs. on Crit's meter. So did the Sea Foam soak recondition the side seal to restore compression in that front rotor? Who knows.
It's getting spark to all four plugs. The carb visually pumps gas into the primaries when you press the accelerator and the engine will race right up to 7000 rpms. So it doesn't seem to be ignition or fuel.
I've checked and rechecked and rechecked for vacuum leaks - none, although as several have noted in this post it does sound like a bad vacuum leak:
Won't idle, no power, sounds like one of the rotors is on vacation. Back to square one.
Maybe I'll rebuild it just because I can't figure out what is wrong with it. But in the mean time if anyone has any ideas I'd sure be glad to give them a try.
I think I'll go work on the Silver One for awhile.
Thanks
Ray
Old Apr 18, 2008 | 03:05 PM
  #46
dbragg's Avatar
Say hello to Mr.Wankel
i think youre trying to fore it to limp until it crashes. just go ahead and plan on pulling and rebuilding it. you can make it better and stronger.
Old Apr 18, 2008 | 03:06 PM
  #47
Jeff20B's Avatar
Lapping = Fapping
Ray, is this your very clean looking engine with complete rat's nest and everything? The oproblem could be originating in one of the single-rotor specific emissions lines lioke the automatic trans modulator nipple, or the 2nd slow air uh... um I don't know what it's called but it's the biggish tube on/under the rear secondary runner that most people don't diagnose very easily because it is hard to see. Or is the shutter valve always closed or very nearly always closed?
It sounds like you've done all the usual things and they didn't work. Maybe it's time to remove the rat's nest and give yourself a more reliable, easier to work on and diagnose setup.
Old Apr 18, 2008 | 04:23 PM
  #48
ray green's Avatar
That's the one Jeff and it was running great until this problem showed up last week. It does have the rats nest and you may be right, there could be a problem in there somewhere. I'll take another look at the shutter valve. I've sprayed for vacuum leaks and all the tubes are in good shape, so I don't think there is a vacuum leak but there could be a problem with a solenoid or something. Tomorrow I should have more patience. Removing the rats nest is a possibility if I can be sure it's the cause of this mess.
Your point is well taken Donny, a rebuild is advised after 150,000 miles anyway. But still I'd like to know what's wrong first - imagine rebuilding the engine, putting everything back together and still having the same problem?
Old Apr 18, 2008 | 05:56 PM
  #49
Box_Man's Avatar
I hate drum brakes
I just remembered something that my motor did a long time ago. I had a jet unscrew and fall out in the float bowl. It was a jet for the secondaries, so it only acted up when they opened up. I ended up pulling the top off of my carb and discovering the jet sitting in the bottom of the front float bowl.
Old Apr 18, 2008 | 07:45 PM
  #50
ray green's Avatar
Yeah I'm thinking those jets too, clogged, not loose. Something Ken mentioned back on page 1 and Crit reminded me about this evening.
RX-7 colleague Mike is coming over tomorrow, we'll pop those puppies out and take a look. Mike has 250,000 miles on his 12A and he doesn't even use MMO.
