Electric Fan ??????? how many CFM, how big
Old Feb 21, 2005 | 03:24 PM
onePOINTthree's Avatar
N/A is teh WIN!
well, i could eather keep driving with a broken fan clutch (aka the fan doing jack **** at temp) or i could do this... which would you choose? I'm getting a Fluidine or Koyo anyway to help with the cooling. I think it will be more then efficent enough for those 20 min sessions at road courses. It's like 37* outside right now so I'm not too worried about over heating and it only get up to around 90 tops durring really hot summer days.
Oh yeah I've got a question... Would removing the A/C Condenser help the car get a little more airflow and run cooler? My compresser has never worked and the system has a small leak somewhere so i'm removing all the A/C stuff
Old Feb 21, 2005 | 03:36 PM
SonicRaT's Avatar
Super Raterhater
I use fiero fans, their shroud covers damn near the entire radiator, and it looks pretty clean when installed properly. Of course, the stock fan IS better, but for the sake of how much crap I cram in/move around/etc, it works better for me this way. Using the microtech to trigger it (hate those damn thermoswitches, always would fail on me)
Old Feb 21, 2005 | 03:47 PM
Digi7ech's Avatar
I break Diff mounts
A few guys here use Ford Tuarus fans. They say they do something like 3800 cfm1!
I have a Permacool Finger chopper sitting in my room waiting for me to fab a shroud.
I also bought the Black Magic temp switch.
If you aren't modding your hood/Hmount then an E-fan isn't really needed.
The stock shroud has held up and can rarely be beaten.
I'm kind of thinking of putting my Permacool on BUT AZ heat is something not to **** with.
Old Feb 21, 2005 | 03:52 PM
  #29
staticguitar313's Avatar
R.I.P. Icemark
^ indeed, i wanna see that shroud when you finish it, you your as good with fiberglass as i tihnk you are, i might have to comission you to make me a new roof . . .
Old Feb 21, 2005 | 03:53 PM
  #30
totallimmortal's Avatar
Is that thing Turbo?
wow i had no idea taurus fan moved that much, i used to have a mercury sable but i somehow broke the crank in it i should have grabbed it's fan
Old Feb 21, 2005 | 07:28 PM
  #31
pinkfloyd's Avatar
not sure anymore
ford escort fans work well to
Old Feb 21, 2005 | 11:11 PM
  #32
NZConvertible's Avatar
I'm a boost creep...
It would increase aiflow through the radiator due to less restriction, but it will not make the engine run cooler. The engine's temp is regulated by the thermostat, so assuming the it was normal before it should should stay where it was. This will slightly improve the cooling system's capacity though.
Originally Posted by Digi7ech
A few guys here use Ford Tuarus fans. They say they do something like 3800 cfm...
And you believe them? Most people wouldn't have a clue how to measure a fan's airflow or have the equipment to do so accurately, and I've yet to see a manufacturer publish this sort of data. More likely they stuck their hand in the airflow and guessed...
Old Feb 21, 2005 | 11:55 PM
  #33
RXSevenSymphonies's Avatar
Turbo Swamp Thing
Actually, I would guess that they stuck their ***** in the fan blades and how much it hurt on a scale of 0-5 is how many cfm it flows from 0-5000
Old Feb 22, 2005 | 12:24 AM
  #34
Parastie's Avatar
Mountain Rotary Mod
The Ford Escort fan has a built in shrowd the covers the entire radiator like it's sock! Also, it can be picked at any junkyard for under $50
Old Feb 22, 2005 | 12:26 AM
  #35
Parastie's Avatar
Mountain Rotary Mod
I have no idea how many CFM the escort fan pushes, but I do know that when I lived in Texas the car ran a few degrees cooler.
Of course, the reason I put an E-Fan on the car was for ease working in the engine bay, plus i kept breaking fan belts. I did fix that though.
Old Feb 22, 2005 | 03:24 AM
  #36
GTU_FAN's Avatar
Nar
You guys are the bomb
