(REFERENCE) The Upgrading a Stock Rx-7 Thread
Old Aug 27, 2003 | 01:50 PM
ZachstylezRX7's Avatar
Originally posted by 82transam
Apparently removing the rear bar makes it less prone to that oh-so-fun snap oversteer. I have yet to try it as I have my hands full fixing all the other little bugs with my newly installed suspension.
O well where is the fun in not having any oversteer?
Drift till i die!
Zachstylez
Old Aug 27, 2003 | 09:25 PM
82transam's Avatar
Never Follow
Drift till i die!
Zachstylez
You really want more of a neutral car for drifting, having it biased highly towards oversteer would make it uncontrollable. Drift is about controlling a slide, not just sliding around, any camaro or firebird can do that.
Old Aug 28, 2003 | 10:48 AM
CHUCKCAT's Avatar
Ok this mybe a dumb Question but we inject H2O into piston engines at high RPM to bump up compresion Would this work on a rortary or would it be to hard on the seals
Has anyone tryed this
I gess I'll do a search but I wanted to get this form thinking about it tell I can get back on
Old Aug 28, 2003 | 12:29 PM
  #29
fatboy7's Avatar
Got Boost?
Water injection is somewhat popular among highly boosted rotory owners. They use it mostly as an anti-detonate though. That allows some serious boost to be used.
Old Aug 28, 2003 | 01:39 PM
  #30
CHUCKCAT's Avatar
ON PULLING TRACTORS USUALY NOT GAS BUT SOMETIMES
WE PUT IT IN BEFORE THE TURBO TO MAKE AIR DENSER
AND TURBO SPIN FASTER ALSO IN INTAKE TO RAISE COMPRESION
THIS IS DONE AT FULL SPEED AT END OF PULL
Old Aug 28, 2003 | 03:19 PM
  #31
RoToReX7's Avatar
In Loving Memory of Dave
simple tune up, oil change, oil filter, NGK spark plugs, coolant flush
Old Aug 29, 2003 | 11:05 PM
  #32
excitingleopard's Avatar
Prosthetic head.
And what is this rear sway bar removal? I can't find one but i am an idiot... and why is it so beneficial?
Zachstylez [/B]
Circled.
Old Aug 30, 2003 | 01:38 AM
  #33
diabolical1's Avatar
i'll keep it simple ... i was going to say start with a good, COMPLETE tuneup, but others beat me to it ...
so i'll move to the next "often-overlooked" item ... refurbish your suspension bushings - ALL of them - either before or during before suspension upgrades.
also replace engine and tranny mounts ...
Old Aug 30, 2003 | 02:09 AM
  #34
Manntis's Avatar
add to cart
Front swaybar - I put the RB one with poly bushings on Pamela and she cornered far, far better for having done so.
Old Aug 30, 2003 | 04:28 AM
  #35
jimmyrose99's Avatar
does anyone know if they sell rb stuff in australia, i want this damn exhaust but too slack to look around for myself
thanks
Old Sep 1, 2003 | 04:21 AM
  #36
CHUCKCAT's Avatar
I found 20-50 Castrol Syntec makes my rotary run alot better than the regular oil the old owner had in it
But it's exaust will burn your eyes
any synthic oil would probly give you this same afect
synthic don't burn like reg oil so it seems to do a better job of lubing
most of you probly run synthic but I found a few people in my town that just run anything and say oil is oil
I got a good share of power out of this
If you disagree please tell me!
Old Sep 1, 2003 | 09:49 AM
  #37
SimonKaos's Avatar
This makes me wonder what kind of goo is being fused to the inerts of your rotor housings if its not being burned off??
Simon
Old Sep 2, 2003 | 12:14 AM
  #38
Yeah i was under the impression that since rotary engines naturally burn oil, synthetic was not good for them.
Zachstylez
Old Sep 2, 2003 | 12:30 AM
  #39
yeah i was told that too. specifically - "DO NOT put synthetic in a rotary"
  #40
coldy13's Avatar
Yeah, shutup kid.
It depends on the brand of synthetic used. Some of them burn fine, others leave things behind and don't completely burn. I don't use synthetic, so I've never really looked at which brands burn good and which don't.
Old Sep 2, 2003 | 01:35 AM
  #41
Yeah this is a much debated topic so i am sensing an internet forum fight coming soon.
Zachstylez
Old Sep 2, 2003 | 01:56 AM
  #42
13B4port's Avatar
Will Work for Beer
back to upgrading from stock. on se's go take that freakin air box off and get a rubber sewer adapter(home depot has them for $3) 2in to 3in(it's tight but will fit perfectly)and a medal braket that looks similar to this http://jerad.travisbsd.org/flang.jpg then go get a cone filter. use the sewer adapter to connect to the air flow meter from the TB. and then use that braket on the other end of the air flow meter and put the cone filter on the end. this works real great if you upgrade you intake manifold to a s4 or s5 intake. if you do upgrade to that intake, go to racing beat and get a injector hole plug kit. it's full alluminum. cut the square braket in half, and cut about 3/8 to 1/2 in off the top of each plug. goto the secondary injector holes and take the plastic seats out and shove the plug in and then the 1/2 of the sqare on that and tighten it down with the supplied screws. great mod 10-15 hp. and very easy to do. takes about 2 hours with all the equipment.
jerad
Old Sep 2, 2003 | 02:07 AM
  #43
In addition to 13b4port's post, if you want to keep your air pump, then an awesome way to add some great looks with a clean install is to go to Schucks or any parts store and get a pretty small breather for about 15 bucks. Either pop it onto the air pump and put a bracket on it from Home Depot. Or if it is too small, like mine was, just drill out the hole on the breather until you get the perfect size for it to squeeze on the air pump tube. Add a bracket and you are set. Doesn't do a god damn thing for performance, but it does look pretty slick.
O yeah. You can go to a performance racing store and pick up the adapter that 13b4port was talking about. Ask for the Toyota one. It will run you 20 bucks which is more than Home Depot's but if you want a sure thing then it is a direct fit.
Zachstylez
Old Sep 2, 2003 | 03:15 AM
  #44
CHUCKCAT's Avatar
sorry I did not know it was that touchy
thanks 13b4port for getting us back on track
we are tearing one down tomorow to port it
I gess I will see what it looks like its had syn in it 2 years now and we had it apart 2 years ago for a bad rotor thats why we went syn because of all the black tar that was in it from the burnt petrolem oil maybe that was the wrong move I do know some makes of syn say on the can not to run there brand in a rotary?
Old Nov 16, 2003 | 10:22 PM
  #45
180sx-x's Avatar
Zoom-ing Goon.
kinda late, but on the oil issue, here is what sport compact car said wen talking to a rx7 specialists*note* this is for a FD, but a rotary is a rotary...*
"Dino or Synthetic motor oils? That's the big question. While Mazda Corp. has officially forbid the use of synthetic motor oils in their rotary engines, Mostly Mazda strongly recommends the use of Redline synthetics products, in the motor, differential and in the transmission. The unofficial "inside story" behind Mazda's statement is quite interesting. Apparently, in the early 1980s, Mazda's racing team had lubrication problems using a certain brand name synthetic motor oil. Instead of disclosing the particular oil brand and potentially getting faced with a lawsuit, Mazda made an unfair general statement, suggesting that all synthetic oils were incompatible with their rotary engines. Redline motor oils have been successfully used in rotary race motors for nearly two decades. Their motor oils offer improved film strength over other motor oils, synthetic or non-synthetic. Synthetics also extend the life of the turbochargers by resisting bearing "coking" typically associated with traditional oils. We used Redline 10W/40 high performance motor oil for Project RX-7. At over six dollars a quart, it is hardly inexpensive. However, a good motor oil is the best insurance against premature engine wear."
Old Nov 17, 2003 | 12:47 AM
  #46
10,000's Avatar
redline your **** at least once on every outing. keeps the carbon deposits down, keeps compression healthy and power up.
Old Nov 17, 2003 | 03:30 AM
  #47
fitzwarryne's Avatar
Over the ownership of my 12A engined RX-7 I have researched much of the information on this forum to arrive at a good upgrading bolt-on package for a stockport which is reliabille, economical and quick, REQ for short.
My REQ upgrade is:-
ENGINE
 modified Nikki carb[bored out venturi, larger jets, modified accelerator pump, plenumed secondary inlets, mechanical linkages,] Stirling style!
 matched inlet manifold,
 K&N air filter
 Custom exhaust system based on long primaries, a sports muffler with 2 ¼” pipe. Pineapple concept
 13BT Turbo fan/radiator
 Heavy Duty Clutch
 Deleted airpump and airconditioner but dual fan belt pulley
 10mm high performance ignition wires, NYK plugs
SUSPENSION
 Upgraded shocks, KYB high performance sports
 Lowered 1 1/4 inches with upgraded coils[145f110r],
 25mm stronger front swaybar
 poly bushes
 Heavy duty Bendix brake pads, top brake fluid
WHEELS
Enkei 14 inch alloy wheels with 205-60 Dunlop W10 tires
What I have also considered but have yet to be convinced are:-
Electric radiator fan
DLIDFIS
Bigger wheels
Front air dam and rear spoiler
Weber carb
'Cold 'air inlet
Upgraded fuel pump and regulator
Steel braided brake lines
Strut tower brace
My package seems to work well - outstanding handling and 28mpg cruising at 70mph. 24mpg round town. Low and midrange power is great with standing 1/4 in the low 15s without being too wild, 14.6 seconds the best when really trying.
Old Dec 31, 2003 | 01:12 AM
  #48
jimwww's Avatar
jimwww
On a 5 liter mustang if one replaces all the fluids one gains seven horsepower.. (owned 6 of them)
If you replace tranny fluid and rear end fluid.. it has got to help..
I will be doing it to mine.
Old Dec 31, 2003 | 08:32 AM
  #49
Bruceman's Avatar
Rotor Power Rules
Install an electric fan on the radiator,
this will free up a few hp and more importantly get rid of the propeller noise and release the true rotor music.
Make sure your carb secondaries are at least opening!
Old Jan 13, 2004 | 04:32 PM
  #50
jaspertrix's Avatar
Newbie
Another basic mod/ tune up to make it run right send injectors to be balanced and blueprinted. was mail in a and cheap. Not sure, but on motorcycle when got K&N and free flowing exhaust needed to upgrade jets, maybe bigger injectors may be in order here.
