My 81 build
Old Nov 18, 2009 | 06:52 AM
Frankenmazda's Avatar
You wanna do what?????
KY My 81 build
So what do you guys think of my body kit so far? I have one more mold to make for the front air dam and body is about done.
Old Nov 18, 2009 | 07:07 AM
ourxseven's Avatar
1/1 scale Hot Wheels
wow
for a frankenmazda looks awesome
I like the back alot , the front fender might be a little too square near the door crease for me . seems a little smoother curve at that point might balance the look a bit more ....
Old Nov 18, 2009 | 09:15 AM
theNeanderthol's Avatar
the torquinator
wow Very impressive work.
Old Nov 18, 2009 | 09:26 AM
openshot's Avatar
Wankel Me This!!
holy crap that looks nice.
Old Nov 18, 2009 | 10:16 AM
Willy92's Avatar
Wild Yet Smooth
Daaaaaaannnnng!!!!
Old Nov 18, 2009 | 03:13 PM
mazdaverx713b's Avatar
Have RX-7, will restore
neat. what are your plans for the car?
Old Nov 18, 2009 | 05:35 PM
plans
A quick, good handling street car. To be honest I've got over three years in the building so far and I really haven't thought about drivetrain. It's a GSL so it has limited slip, rear disks. I had the axles drilled for a 4x4.5 pattern and swapped the front for GSL-SE spindle assemblies and brakes. It was an auto but I'm doing a manual swap as well.
I'm going to do a ReSpeed rack and pinion swap because I can't imagine not having it!
Old Nov 18, 2009 | 06:23 PM
thumbs up! sounds like a great plan to me!
Old Dec 7, 2010 | 11:16 AM
KY still kicking
Bet you guys thought I was gone. Been developing a residential wind turbine so I took a break. I'm back to it now. Have the fiberglass on the front finally done. Now I have a ton of Bodywork! Hoping to have it on the road by the end of spring.
Old Dec 7, 2010 | 11:27 AM
Gryffinwings's Avatar
That is sick. What are your plans for the engine, suspension, and brakes? Also what size wheels and tires are those?
Old Dec 7, 2010 | 11:33 AM
dream36realms's Avatar
死*神*
i like it.
Old Dec 7, 2010 | 03:02 PM
slidewithstyle's Avatar
:Nice to see a great looking 1st gen in Ky. Are you making duplicates of the body i love the way it looks
Old Dec 7, 2010 | 03:14 PM
Talking well...............
suspension, I'm going with a ReSpeed rack and pinion for steering. I can't get myself to put the sttering out of a truck back in plus I'm going to a power rack.
I have 85 GSL-SE front struts, brakes and I'm going to go with the stock brakes with good pads and new rotors for now. The car is going to be a lot lighter than stock so until I need them I'm going to try to get by with the stock ones.
I'm going to raise the front strut towers as far as possible without hitting the bottom of the hood so I can increase the drop without bottoming on the bumpstops. With ReSpeed springs and coilover kit it should handle pretty well.
I raised the rear shock towers 3 inches so with coilovers I can sit it really low. I lowered the bottom 4 link mounting holes on the axle by about 2 1/2 inches to get the lower links level at ride height. I'm going to make roll center blocks to fit between the steering arms and the struts up front to get the control arms more level at static ride height. That will do for now for the suspension. There is a lot of adjustability built in to set things up.
The wheels are 15x12 Greg Weld wheels in the rear, P295x50-15's and 15 x 10 with 225x50-15 in the front.
Anyone wanna help me sand
Old Dec 7, 2010 | 03:18 PM
How did you make the molds and get everything square?
Old Dec 7, 2010 | 04:04 PM
Directfreak's Avatar
I am a Jeeper Now.
Old Dec 7, 2010 | 04:18 PM
Bearzah's Avatar
Me Wantee Da' Boostee
nice!
Old Dec 7, 2010 | 04:25 PM
hemotape's Avatar
what is this kit and where can i find one?
Old Dec 7, 2010 | 04:51 PM
Bearzah's Avatar
Ugh.. just buy a Corvette (1968–1982)....
Old Dec 7, 2010 | 06:09 PM
molds
I made the molds myself but I don't see selling parts. Nothing would fit a factory car.
Here is another
Old Dec 7, 2010 | 06:15 PM
trochoid's Avatar
Old Fart Young at Heart
Nicely done!!!! Be prepared to make frequent repairs on the front lip. I've lost count how many times I've snagged mine. When that happens it cracks the fender arch/lip just forward of it's center and where the FG fenders bolt to the center header panel. Yours may not crack in the same places since your joints are in different places. I've been toying with the idea of cutting off the rolled front lip on mine and adding a 4" flexible skirt to help prevent further damage and repairs.
My only dislike is the side skirts, too boxy, need the sharp angles and flat areas rounded out.
Keep up the great work and post more build/process pics.
Old Dec 7, 2010 | 06:20 PM
I am a Jeeper Now.
Old Dec 7, 2010 | 07:15 PM
flight_of_pain's Avatar
its supposed to do that
Looks more like an Opel than a vette to me.
Old Dec 7, 2010 | 07:26 PM
hemotape's Avatar
not bad lookin... I think that 7 was built with the part off of a ford ranger
I was thinking about trying to build one similar, but the tail lights on that kit are effing sexy with that setup.... i mean, i know it's a second gen, but dizamn that woul look sweet on my 7
Old Dec 7, 2010 | 07:54 PM
skirts
Yea the sideskirts aren't finished yet. Almost finished with the fiberglass though!!!!
The car will actually sit about an inch and a half higher than it does right now.
I actually like that Opel Gt. I built one for a guy a long time ago very similar to that. He had an LT1 out of a vette running through a rock-crusher with a ford 9 in rear. Fast car!!
Old Dec 10, 2010 | 08:29 PM
Viperx7's Avatar
I like it. Definately one of a kind.
Einheri
Oct 7, 2015 12:23 PM
